WordPress Plugins: A Beginner's Guide
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
mr.306
Post15-10-2009, 10:30    Subject: WordPress Plugins: A Beginner's Guide Quote
HELLO!!!
Could someone please provide me with some instructions on how to use the plugins?
"When I click on the KPerformance folder in the plugins directory, I get the following message:"
The VDS/APIProxySwitch is not running or is unreachable.
How do I start data acquisition in KPower and VCScope?
THANK YOU!!!
Translated on 24-07-2026, 21:38.
Back to top Profile PM Email
Post15-10-2009, 15:45    Subject: WordPress Plugins: A Beginner's Guide Quote
You have a private message.
Translated on 24-07-2026, 21:39.
Post16-10-2009, 16:29    Subject: WordPress Plugins: A Beginner's Guide Quote
Your serial number is valid.
Okay, so it works like this: KPerformance can't be started directly, but rather through the "Plugins" button in VCDS. So, you go to the measuring blocks and find the speed reading, then click on "Plugins" and then select KPerformance (for TDI engines, it's usually found in measuring block 6).
The operation is actually quite straightforward: just enter the area you want to measure and press "Start." Then, when the light turns green, proceed.
When using KPower (launched via the Windows Start menu), it's best to press the 'F1' key; a window containing the user manual will then appear.
KDataScope can also be opened through the Windows Start menu.
I almost forgot about Kfuel; it's not mentioned in the product description, but you can use it to conduct fuel consumption experiments. The setup is similar to KPerformance, but you need the instantaneous fuel consumption rate (in liters per hour) as a measurable value (for TDI, I believe it's measurement block 15, and speed is likely measurement 6).
Translated on 24-07-2026, 21:40.
No new posts Keyless Entry Installation Guide by IN.PRO Troubleshooting & Guides
No new posts Plugins 704.1RKS vs 711.1beta On-Board Diagnostics (OBD)
No new posts VCDS (VAG-COM) Plugins deutsch... On-Board Diagnostics (OBD)
No new posts Tuning mit VAG COM (Anleitung -> !?) Diesel Engine Technology
No new posts Do you need a DZR guide? Diesel Engine Technology
