EDS Regulation flawed! Found the mistake! (Solution)
marcello
Post22-02-2003, 11:38    Subject: EDS Regulation flawed! Found the mistake! Quote
Hello everyone, I've found the error. It was a faulty ABS sensor at the rear. I re-examined the data blocks and noticed that one sensor at the rear was providing a lower signal than the others, but only up to about 8 km/h, then it showed normal values again. The cause: Once, a wheel nut was over-tightened at the rear, which slightly bent the sensor, so that the air gap between the sensor and the toothed disc was no longer correct.
But NO error was stored in the control unit!
New sensor installed, and everything was fine again.
Maybe I could help someone with the same problem.
MARCELLO
Back to top Profile PM Email
Post23-02-2003, 11:11    Subject: Great! (No Title) Quote
History /viewtopic.php?t=2201
Ratings - EDS Regulation flawed! Found the mistake!
No new posts Audi A3: Faulty Fan Repair & Service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4/A6 Doku: Faulty Fan Control System Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Boost Control Problem - Golf4 AXR Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat AVG: Injection Start Control Error 17656 On-Board Diagnostics (OBD)
No new posts Audi A6 Error 01117: Load Signal Fault Diesel Engine Technology
No new posts Coolant Leak: Audi Problems - No Faults Found Diesel Engine Technology
No new posts Vibrations Issue: Troubleshooting Near 2000 RPM. Diesel Engine Technology
