teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
23-11-2009, 14:51 Subject: WFS Locked Out: Troubleshooting & Solutions |
Hello.
From 2007 onwards, is it possible to program the car's central locking system so that someone can be locked inside the car, but they cannot open it from the inside?
Also gedachter Fall du gehst tanken und lässt Personen im offenen Auto zurück. Setzt dich kurz zum Kaffe hin und klack ist endgültig zu. KeAnyone can leave.
When the key is inserted into the ignition, it can sometimes come out when opening the door for the second time.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 14-09-2026, 2:14.
Profile PM Email Garage |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2406 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
23-11-2009, 15:30 Subject: WFS Locked Out: Troubleshooting & Solutions |
Hello Klaus,
If you could provide the engine control unit (ECU) number, it might be possible to give a more specific answer.
Here's what I can say: The fact that the door cannot be opened from the inside is, in principle, intentionally designed by the manufacturer. Otherwise, burglars could easily unlock the car from the inside through a gap or a slightly open window, etc. This feature is called the "Safe" function. From a theft prevention perspective, it's a positive thing.
Can it be completely disabled? I would only recommend checking the vehicle's onboard network control unit (BCU) using VCDS to see if the safety function can be deactivated, or what happens if you mark it as not installed (keywords: "North American markets," or "double locking not installed").
If you want to control this intentionally: A single press of the lock button on the FFB (Front Front Button) will lock the vehicle and then "secure" it. Pressing the lock button again (within a short time) will "unsecure" it. However, the vehicle will remain locked.
Guste.
Translated on 14-09-2026, 2:15.
Profile PM Garage |
23-11-2009, 15:46 Subject: WFS Locked Out: Troubleshooting & Solutions |
Thank you, Guste. I have observed this issue in 5 different T5 models of various production years.
Of course, breaking a window and then attempting to open it from the inside twice should be prevented.
I'll try using "zu" twice.
Translated on 14-09-2026, 2:17.
