STG 46: No Response? Troubleshooting Guide.
biposta916
Post24-03-2010, 15:45    Subject: STG 46: No Response? Troubleshooting Guide. Quote
Hello, I'm quite new to this forum...
I'm having a problem with my Golf 4, 1.9 TDI. I programmed the auto-lock function in module 46. Unfortunately, I've discovered that module 46 can no longer be found.
Das wundert mich da ich es ja mal erreicht hatte. Habe im STG 46 Kanal 04 aktiviert. Go for it! / Go ahead!
VAG-COM version: DRV 311.3-S.
Vehicle type: 1J - VW Golf IV (A4)
Scan: 01, 02, 03, 08, 15, 17, 19, 22, 35, 46, 56.
Address 01 -------------------------------------------------------
Control unit: 038 906 019 AT
Component: 1.9L R4 EDC 0000SG 1575.
Encoding: 00002
Shop #: WSC 01266
WVWZZZ1JZ3W634432 VWZ7Z0C7574192
No error code found.
Address 03 -------------------------------------------------------
Control unit: 1C0 907 379 M
Part number: ESP FRONT MK60 0102.
Encoding: 0019458
Shop #: WSC 01266
Address: Skip 15 airbags.
Address 17 -------------------------------------------------------
Control unit: 1J0 920 826 C
Part: COMBINED SPEED/DISTANCE SENSOR - VDO V20.
Encoding: 05112
Shop # : WSC 00000
"One error found:"
01336 - Corporate Data Bus Comfort.
80-10 - in single-wire operation - disconnected.
Address 19 -------------------------------------------------------
Control unit: 6N0 909 901
Component: Gateway K<->CAN 0001.
Coding: 00006
Shop #: WSC 01266
"One error found:"
Address: 56
Control unit: 1J0 035 153
Component: Radio BNO 0007.
Encoding: 00001
Shop #: WSC 01266
"Ende" translates to "end" in English.
It would be really nice if someone could help me!
Translated on 16-08-2026, 4:06.
Post24-03-2010, 17:53    Subject: STG 46: No Response? Troubleshooting Guide. Quote
Here are some things that come to mind spontaneously:
- The diagnostic cable uses a USB to RS232 interface adapter. -> It does not function reliably.
- Program settings in VAG-COM have been temporarily modified.
- The STG46 device has frozen; try disconnecting the battery and waiting a while. Be careful not to lose any radio codes or other settings.
Translated on 16-08-2026, 4:12.
Post24-03-2010, 21:26    Subject: STG 46: No Response? Troubleshooting Guide. Quote
I've noticed this in the scan:
1 Error found:
80-10 - in single-wire operation - Disconnected
and 46 has something to do with the comfort bus icon_wink.gif.
Translated on 16-08-2026, 4:13.
biposta916
Post25-03-2010, 9:11    Subject: STG 46: No Response? Troubleshooting Guide. Quote
Okay, thanks. I'll try disconnecting the battery and see what happens.
Translated on 16-08-2026, 4:14.
michiglaser
2007 Audi A4 Avant
Post25-03-2010, 23:36    Subject: STG 46: No Response? Troubleshooting Guide. Quote
I have experienced this problem multiple times before.
Disconnecting the battery can help.
Have you added or modified anything else to the car (regarding the single-wire operation of the CAN bus)?
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
biposta916
Post26-03-2010, 9:37    Subject: STG 46: No Response? Troubleshooting Guide. Quote
Good morning.
I just had the service done recently (STG 17). I'm going to try it out right away now.
Translated on 16-08-2026, 4:15.
biposta916
Post26-03-2010, 10:14    Subject: STG 46: No Response? Troubleshooting Guide. Quote
Everything's fine now, I disconnected the battery and everything is working properly.
biposta916
Post26-03-2010, 10:16    Subject: STG 46: No Response? Troubleshooting Guide. Quote
And of course, many thanks to everyone!
Thank you.
No new posts 4Motion keine Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Allroad Luftfahrwerk - keine Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Unverschämte Antwort von VW bzgl. Biodieselschaden Diesel Engine Technology
No new posts What oil is suitable for the TDI? Here is an attempt at a... Diesel Engine Technology
No new posts Diode as a replacement for LMM - Solution and answer needed Diesel Engine Technology
No new posts A6 96 keine Leistung Diesel Engine Technology
