RedR32 Schrauber
Joined: 12/21/2008 Posts: 1071 Karma: +11 / -0 Location: Bad Lobenstein 1998 Volkswagen Golf Premium Support
21-12-2009, 22:57 Subject: EMS in ARL: Benefits and Applications |
Where can I get a 240 EMS? Which type of vehicle uses this?
Interresant wäre eine Lösung wie bei den alten tdis 1z z. B. wo Einmassenschwungrad mit gefederter Scheibe eingebaut war. Klar-gibts alles im Satz von Sachs Race oder eventl. auch von spec.. Aber ich möchte mir das schweineteure EMS nicht von den kaufen. HaDoes anyone have a plan?
For Leon. 2010 Caddy kombi life 103 tdisg6 BMM KXW
reflexsilber met.
Translated on 03-10-2026, 6:51.
Profile PM Garage |
michiglaser Blaumann
Joined: 05/03/2007 Posts: 274 Karma: +6 / -0 Location: Lkr. KEH 2007 Audi A4 Avant Premium Support
22-12-2009, 0:18 Subject: EMS in ARL: Benefits and Applications |
Think twice before you get an EMS.
I wouldn't install it again (in a regular car). T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 03-10-2026, 6:52.
Profile PM Garage |
RedR32 Schrauber
22-12-2009, 21:22 Subject: EMS in ARL: Benefits and Applications |
Hi michi, why don't you try installing it again? So far, I've had positive experiences with EMS and a cushioned washer regarding the noise behavior of the transmission in vehicles with a distributor injection pump and a 5-speed gearbox.
However, since PD engines have higher injection pressure and are therefore subjected to greater stress on the transmission/dual-mass flywheel, I'd like to hear your experiences on this topic. 2010 Caddy kombi life 103 tdisg6 BMM KXW
reflexsilber met.
Profile PM Garage |
29-12-2009, 14:32 Subject: EMS in ARL: Benefits and Applications |
Gerade wenn man mit ~70 - 80 km/h auf ebener Strecke ohne viel Last dahineiert, fährt man mit ZMS eigentlich im 6. Okay.
With EMS, you constantly experience the shift between the torque of the wheels and the motor's torque, resulting in a constant rattling sound from the transmission.
While idling (e.g., at a traffic light), I also keep the clutch pedal pressed down to avoid the rattling noise.
It's annoying in the long run - and I suspect it's not exactly good for the transmission either. T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 03-10-2026, 6:53.
Profile PM Garage |
RedR32 Schrauber
31-12-2009, 18:21 Subject: EMS in ARL: Benefits and Applications |
Then everything will stay as it is, and I'll just install a reinforced pressure plate from SRE. 2010 Caddy kombi life 103 tdisg6 BMM KXW
reflexsilber met.
Translated on 03-10-2026, 6:54.
Profile PM Garage |
