Defective Engine Control Unit: Find Replacement ECU
Nightflight74
Post01-02-2010, 13:25    Subject: Defective Engine Control Unit: Find Replacement ECU Quote
Hello everyone who enjoys tinkering and working on things in this forum!
I recently bought a used 1995 Volkswagen Golf Cabrio TDI at a good price, but it has the following problem:
Since the engine control unit (ECU) is defective, I am looking for a replacement.
Mine has the number 028 906 021, production year.
Bosch part number 0 281 001 247/248.
Can someone tell me what other devices I can still use?
Thank you in advance....
Translated on 02-10-2026, 6:39.
Post01-02-2010, 14:54    Subject: Defective Engine Control Unit: Find Replacement ECU Quote
Which engine are we talking about?
Manual or automatic?
It should be worth the effort to make sure that we don't have to go searching for it.
Translated on 02-10-2026, 6:40.
Wiesel
Post01-02-2010, 18:43    Subject: Defective Engine Control Unit: Find Replacement ECU Quote
It is a 1Z / AHU.
The control unit with part number 028906021BJ has been replaced with a unit with part number 028906021FS.
Micha
Nightflight74
Post01-02-2010, 20:12    Subject: Defective Engine Control Unit: Find Replacement ECU Quote
Hello everyone,
Thanks for the quick replies!
"No, it doesn't solder properly; it just makes noise. Also, since it's the older model with two circuit boards, and I want more power anyway, I thought I'd ask if there are any replacement parts available for the BJ model!"
Translated on 02-10-2026, 6:41.
Post01-02-2010, 20:20    Subject: Defective Engine Control Unit: Find Replacement ECU Quote
it makes noise
icon_rolleyes.gif which ones?
Translated on 02-10-2026, 6:42.
Nightflight74
Post01-02-2010, 20:39    Subject: Defective Engine Control Unit: Find Replacement ECU Quote
Well, after I paid for it and picked it up, I noticed that it didn't accelerate properly starting around 3000 RPM!
So, I went to the friendly mechanic to have the error codes read.
Contrary to my expectations, there were no errors!
The fuel injection pump was replaced by the previous owner and comes with the invoice! (2500 km ago).
After the car had already reached 230,000 km and I felt the engine was generally underperforming, I installed the 0.205 injectors from an AFN model.
Result: The engine is working hard, but at around 3000 RPM in the highest gear, it doesn't accelerate any further!
So, I installed a boost gauge, and it turns out that in 5th gear, around 3000 RPM, the gauge needle starts to fluctuate between 0.5 and 1.5 bar...
LMM (mass airflow sensor) and boost control valve tested by swapping them from another vehicle - no change!
Wastegate linkage checked - also operating smoothly. Vacuum actuator also OK!
Thanks again for your help!
Translated on 02-10-2026, 6:43.
Post01-02-2010, 20:48    Subject: Defective Engine Control Unit: Find Replacement ECU Quote
...and then the only thing that could be broken is the MSG...? icon_eek.gif ... I don't understand that. The tightness of the LD system should be checked, a possibly clogged catalytic converter... many things could be defective. A MSG usually only breaks if someone messes with it using a soldering iron...
Translated on 02-10-2026, 6:45.
Nightflight74
Post01-02-2010, 20:59    Subject: Defective Engine Control Unit: Find Replacement ECU Quote
Well, I've checked all of that too!
The cat was kicked out on the second day because I thought it was going to be too much!
Funny enough, everything works up to the 5th gear!
I've already spent hours in the workshop, racking my brains about it...
I have to mention that I'm a professional in this field, but unfortunately, I don't have VCDS to check the measuring blocks.
Translated on 02-10-2026, 6:46.
Post02-02-2010, 5:15    Subject: Defective Engine Control Unit: Find Replacement ECU Quote
Nightflight74 wrote:
I have to say that I am a professional in this field, but unfortunately, I don't have VCDS to check the measuring blocks!
Why is it that the very thing that's broken is something you can't assess, measure, or evaluate?
If you're knowledgeable in the field, VCDS is definitely not a bad investment, is it?
Translated on 02-10-2026, 6:47.
Post02-02-2010, 7:41    Subject: Defective Engine Control Unit: Find Replacement ECU Quote
I'd bet that the investment is worthwhile, especially if you plan to tinker with it, even if you've already started replacing things like nozzles. Since you're knowledgeable in the field, it's not necessary to emphasize that any tuning should be based on a healthy and functioning mechanical/electrical system, and shouldn't be used to fix problems.
What does the DiFi look like?
Translated on 02-10-2026, 6:48.
Nightflight74
Post02-02-2010, 14:51    Subject: Defective Engine Control Unit: Find Replacement ECU Quote
Wow, thanks guys for your cooperation!!!
I'm sure that VCDS is definitely not a bad investment...
I'll probably end up buying one eventually, but I was hoping to find a more affordable option! (I'm a bit short on money right now.)
That's also the reason why I decided to go with the Golf TDI.
I had the DiFi test done at the same time as a service appointment because I wasn't sure when it was last performed.
I wanted to be on the safe side and get the standard things done before winter arrived.
While I was driving on the highway this morning on my way to work, the engine revved higher than 3000 RPM.
(I was late again...)
On the way home, I wanted to know for sure, so I floored it, and at 3000 RPM, the needle started fluctuating between 0.5 and 1.5 bar on the LDA (Low-Pressure Differential Analyzer).
Okay, I'll try to be more understanding; I might have made a mistake.
(Slowly, this is turning into an endless story...)
Translated on 02-10-2026, 6:49.
slow-moe
Post02-02-2010, 15:59    Subject: Defective Engine Control Unit: Find Replacement ECU Quote
It sounds like there's a problem with the boost pressure control system. Perhaps the wastegate valve isn't opening. A common issue is that oil accumulates in the line leading to the boost control valve and carbonizes. It's also possible that the hose to the boost pressure sensor is frozen shut in the engine control unit.
Translated on 02-10-2026, 6:51.
Post02-02-2010, 16:53    Subject: Defective Engine Control Unit: Find Replacement ECU Quote
You can push the valve open with a 50 ml syringe and observe it at the same time.
A test that costs approximately €0.00 - because you can get the syringe for free at a pharmacy if you ask nicely.
Translated on 02-10-2026, 6:52.
Nightflight74
Post02-02-2010, 19:35    Subject: Defective Engine Control Unit: Find Replacement ECU Quote
Hey guys, so I'm not exactly broke again icon_lol.gif.
In my opinion, everything should stay within reasonable limits.
I was just trying to avoid having to buy a VCDS device, which costs around 500 euros and requires a laptop. I enjoy tinkering with cars occasionally, but I generally prefer to spend my free time doing other things.
I went to see the friendly doctor again (he now knows my name).
Error memory read ---> of course, nothing inside icon_confused.gif.
It can probably only be due to the boost pressure regulation.
After replacing all the vacuum hoses and testing a different pressure regulator valve, the only remaining possibilities are the wastegate itself (and the vacuum actuator connected to it has already been checked) or the control unit!
Am I right? Yes, or...?
Thanks again for your help, I really appreciate it!!
Translated on 02-10-2026, 6:53.
Malte1408
Post02-02-2010, 20:10    Subject: Defective Engine Control Unit: Find Replacement ECU Quote
The boost pressure is too high.
This behavior is typical for these older parts. There is no limp-home mode (a reduced-power mode that resets when the ignition is turned off) in this system, at least not related to the boost pressure regulation. No error codes are logged either.
The engine control unit limits excessive boost pressure simply by adjusting the fuel injection volume, and it only does so as long as the boost pressure is actually too high. This is why the boost pressure fluctuates. (It's a protective function and not designed as a closed-loop control system.)
Re-check the turbocharger air hoses and wastegate, including the pressure sensor. Also, verify the correct connections according to the hose diagram.
(This is not a vacuum chamber, and the hoses that control the boost pressure don't have a vacuum, but rather overpressure, and that's why you need to put clamps on them...)
Since you've already installed a pressure gauge, you can easily check the proper function of your wastegate with a pressure capsule by connecting the pressure capsule directly to the compressor outlet or intake manifold (i.e., to the boost pressure). Under full load, a stable boost pressure of approximately 0.5 - 0.6 bar should then be established.
You should also check whether the boost pressure measurement is still accurate, both through the engine control unit itself (using a pressure gauge and VCDS).
Translated on 02-10-2026, 6:55.
Nightflight74
Post02-02-2010, 20:22    Subject: Defective Engine Control Unit: Find Replacement ECU Quote
Malte 1408, I am very grateful to you!!!
"Well done, a very knowledgeable opinion, perfectly written and therefore easy for everyone to understand!"
I'll be doing some troubleshooting tomorrow.
Thank you again.
Translated on 02-10-2026, 6:57.
No new posts Engine Control Unit Errors: 2.5L V6 TDI (No Delete) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Control Unit Failure After Injector Replacement On-Board Diagnostics (OBD)
No new posts Engine control unit (ECU) faulty? On-Board Diagnostics (OBD)
No new posts Dry run --> Engine control unit malfunction Diesel Engine Technology
No new posts Engine Control Unit (ECU) Fault? Diagnose Help. On-Board Diagnostics (OBD)
