dieselmartin wrote: |
The 3C will not ring if you do not connect a phone case.
The Skoda brochure states "optional with or without shell."
So, is the 1Z better if you want to completely retrofit something, because you can save yourself the housing and the cables? |
If no one responds:
You could simply plug the Z1 connector into your car's 3C socket (move the passenger seat back, remove the plastic cover, and connect the plug). Then you can see if it really works without the casing.
I would guess that Skoda means: either with a charging cradle ("optionally with..."), or with a Bluetooth pairing adapter or touch adapter, or just the console without anything plugged in ("without a charging cradle"). But that's just my wild guess. You should check the Skoda owner's manual to see how to perform pairing without a charging cradle...
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It refers to a sudden and strong gust of wind.
