Document: Golf 1J, from week 48/98, Clattering noise after cold start. (Solution)
Michael II
Post05-03-2003, 13:39    Subject: Document: Golf 1J, from week 48/98, Clattering noise after cold start. Quote
Clattering noises after cold start
As the engine heats up, the noise becomes weaker.
Cause:
In certain cases, damage to the coating on the barrel can lead to cold spots.
Solution:
If distinct knocking sounds are detected from the engine after cold start, the following procedure should be followed:
Check oil level and oil pressure according to manufacturer's specifications.
If the oil level and oil pressure are within the normal range, further action must be coordinated with VAG product support.
TschĂźss
Michael II
Ratings - Document: Golf 1J, from week 48/98, Clattering noise after cold start.
No new posts Doku Lupo 6X1 MJ 2001, Clattering noises after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Sunroof Rattle Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Engine Knocking Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Loader Piping After Cold Start Diesel Engine Technology
No new posts Blue smoke on cold start: 1.9 PD-TDI Diesel Engine Technology
No new posts TDI Cold Start: Emergency Mode Troubleshooting On-Board Diagnostics (OBD)
No new posts Cold Start Problems? Emergency Mode Explained. Diesel Engine Technology
