I'm having the following problem:
I would like to disable the standard seatbelt warning system in my Caddy, manufactured in October 2009, with a 2.0L TDI engine and 140 horsepower.
Regarding the STG 17 (combination instrument) --> Coding 07.
I can also get to where I want to go.
So far, so good.
Then, an information window pops up, which displays:
00??x0x: Features/Specifications/Equipment.
+01 = Brake pad wear indicator active.
+02 = Seatbelt warning indicator active.
+04 = Windshield washer fluid level warning indicator active.
6 = Split rear window (Only VW Jetta).
Then, we proceed to country selection, using the numbers 1 through 7.
and
Route characteristics with ratings from 1 to 6.
My original code is 0018101.
That means, if I change the original coding to 0016101 now, then the seatbelt warning indicator should be deactivated, correct?
It's important for me to know if that's true.
If I have made a mistake in my thinking, please correct me.
My question is, if the original number is 18, which is the sum of all the features I have, what does each of those 18 represent?
Because, let's say I already have the first three items of equipment.
Then I arrive at a maximum value of 07. The "
6 = Stufenheck" (split rear window) option is not available because it is only for VW Jetta models.
How can I find out what features are included behind that code, specifically, what all those 18 items represent?
I'm curious to see if anyone here knows the answer; it would be really great.
Sorry, I'm new to this.
