psand
11-06-2010, 19:12 Subject: Hill Start Assist: How to Disable (Solved) |
I have a question: Can I disable the hill-hold assist on my Golf V R32 with DSG using VCDS? And if so, how do I do it (explanation for "VCDS beginners"  )?
Thank you very much for your help!
Best regards, Peter.
Translated on 19-10-2026, 9:24.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
11-06-2010, 21:15 Subject: Hill Start Assist: How to Disable (Solved) |
Normally, yes, please always include a complete vehicle scan ("Auto-Scan") when dealing with issues like this, so that we know exactly which control units and codings are involved.
Have you checked the coding in the control unit for the electric parking brake? It should be address 53.
Translated on 19-10-2026, 9:25.
Profile PM WWW Garage |
psand
12-06-2010, 18:58 Subject: Hill Start Assist: How to Disable (Solved) |
Okay, here's some more information:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BÀume, und die BlÀtter rascheln leise. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen."
Address 01: Engine Label file: RKS\022-906-032-BDB.lbl
Part number SW: 022 906 032 KG, Part number HW: 022 906 032 GP.
Component: R32-DQ-EU4 G 1067
Revision: 1QH02--- Serial Number: VWX7Z0GN3N6802
Encoding: 0000178
Operating number: WSC 01287 785 00200
No errors found.
Readiness: 0000 0000
Address 02: Transmission Label file: RKS\02E-300-0xx.lbl
Part number SW: 02E 300 011 CK, HW: 02E 927 770 AE.
Component: GSG DSG 081 1407
Revision: 04608010 Serial Number: 00000710300595
Encoding: 0000020
No errors found.
Address 03: Brakes Label file: 1K0-614-517-MK60-A.lbl
Part number SW: 1K0 614 517 AD, HW: 1K0 614 517 AD.
Part number: ESP 4MOTION MK60-AT 0102.
Revision: 00H14001
Encoding: 0004744
No errors found.
It should be enough, right?
I read somewhere on the internet that you can only disable the hill-hold assist feature via VCDS on the component with the identifier MK60-AT!?
Translated on 19-10-2026, 9:29.
12-06-2010, 20:32 Subject: Hill Start Assist: How to Disable (Solved) |
Okay, that's enough. That car won't have a control unit address 53.
What value do you have in adaptation channel 58 from the ABS?
Translated on 19-10-2026, 9:33.
psand
18-06-2010, 15:12 Subject: Hill Start Assist: How to Disable (Solved) |
Hello Rainer,
Unfortunately, I only just had the chance to check.
03 Brakes - Adjustment.
Hill-start assist - normal.
Channel 58 - Value 1.
I have now set the value of 1 to 0.
Hill-start assist - disabled!
Translated on 19-10-2026, 9:34.
19-06-2010, 10:05 Subject: Hill Start Assist: How to Disable (Solved) |
Great, thank you for the feedback!
Translated on 19-10-2026, 9:35.
