Measurement data blocks 001-137
VCDS-S
2013 Volkswagen Touareg
Post19-08-2010, 10:46    Subject: Measurement data blocks 001-137 Quote
I've created a PDF file for download.
Okay, I understand. Please provide the German text you want me to translate into English. I will only provide the translation.
If it already exists or is not desired, please delete it. If this is in the wrong section, please move it.
Karma: +807 / -0   Thank you, like it!
Post19-08-2010, 11:54    Subject: Measurement data blocks 001-137 Quote
What's different here compared to the label file? I've parked it before.
VCDS-S
Post19-08-2010, 13:33    Subject: Measurement data blocks 001-137 Quote
Well, I'm not sure, I was just looking for information about the measurement blocks and what kind of data they collect, but I couldn't find anything, or maybe I, as a novice, was just looking in the wrong place. I thought it would be nice to have an overview. If something like that already exists, where can I find it and under what name?
But as already mentioned, if it is not desired or already exists, simply delete it again icon_biggrin.gif.
Post19-08-2010, 16:31    Subject: Measurement data blocks 001-137 Quote
VCDS will show you all of that information. Just hover your mouse over the relevant field or click on the name of the label file (in the top left corner).
No new posts ECU Data Blocks: What You Need to Know On-Board Diagnostics (OBD)
No new posts VW TDI Engine Sensors A4 2001+ - AWX/AVF On-Board Diagnostics (OBD)
No new posts Urgently looking for {BLOCK TYPE} blocks... 2.5tdi AEL an... On-Board Diagnostics (OBD)
