Rail Pressure Sensor: Pinout and Signal Levels
vwSchrauber
Post09-06-2010, 10:10    Subject: Rail Pressure Sensor: Pinout and Signal Levels Quote
Since I haven't been able to find any reliable information (only half-knowledge from self-proclaimed experts on forums like MT, etc.) about this, I wanted to ask if anyone could provide me with information regarding the pinout and signal levels of Bosch rail pressure sensors.
I need this (adapted for a different purpose) to visualize the combustion process (cylinder pressure measurement).
thank you;
Translated on 26-07-2026, 6:39.
Post09-06-2010, 10:32    Subject: Rail Pressure Sensor: Pinout and Signal Levels Quote
Caution: Please check if the rail pressure sensor is fast enough for your needs.
http://rb-aa.bosch.com/boaasocs/index.jsp;jsessionid=4D6B2FAD6086EA2459D7F65E18E8E128.sundoro?ccat_id=274&prod_id=218
I think glow plugs with an integrated pressure sensor would be more suitable; there was a discussion about that some time ago.
Translated on 26-07-2026, 6:40.
vwSchrauber
Post09-06-2010, 15:38    Subject: Rail Pressure Sensor: Pinout and Signal Levels Quote
Hi Rainer,
Shouldn't the rail pressure sensor also be a piezoresistive sensor?
I initially considered using a Beru pressure sensor, but I would need to find one with the right specifications (cone shape, length), and I'm also concerned about the signal output. I'm not very familiar with visualizing data from a rail pressure sensor using an oscilloscope.
The link to the Bosch catalog is really cool, thanks! I didn't know that Bosch releases so much information about the products on the market icon_eek.gif.
Translated on 26-07-2026, 6:41.
vwSchrauber
Post10-06-2010, 12:40    Subject: Rail Pressure Sensor: Pinout and Signal Levels Quote
One revolution at idle speed (800 RPM) takes approximately 75 milliseconds, which corresponds to 360 degrees.
With an injection angle of approximately 5 degrees, the injection duration is about 1 millisecond. Surely the sensor can handle that?
I'll get all the necessary resources, and then I'll let you know if it worked out icon_wink.gif.
Translated on 26-07-2026, 6:42.
Peter vdl
Post29-08-2010, 8:56    Subject: PSG: It's Just So Easy... Quote
Hey VW enthusiasts,
If this is still relevant...
The PSG (Pressure Sensor Module) outputs a voltage proportional to the cylinder pressure, with a linear characteristic curve, and is quite robust for sensor applications. It requires a stabilized 5V power supply and a ground connection to function properly. The rail pressure sensor operates in the same way. Only the models designed for 2000 bar require a 3.3V power supply.
I wouldn't use a common rail pressure sensor because its pressure range is unsuitable. Common rail pressure sensors typically measure from 0 bar to 1500 bar, 1800 bar, or even 2000 bar, depending on the specific model. However, for measuring combustion pressure, you only need a range of 0 bar to 200 bar, and perhaps up to 250 bar if you're really pushing the diesel engine. This means that with a common rail pressure sensor, you would only get a voltage change of at most around 500 mV, whereas with a dedicated pressure sensor (PSG), you get the full voltage range of almost 5 V. In both cases, you will need to build an adapter. However, with a common rail pressure sensor, there's also the added problem that the routing of the hoses changes the combustion chamber, which can distort the measurement. The only advantage of a common rail pressure sensor is its availability as a used part, making it cheaper.
Smoky greetings.
Peter.
Translated on 26-07-2026, 6:44.
No new posts KST 1J0 959 799 Pinout: Connector Diagram & Info On-Board Diagnostics (OBD)
No new posts LMM Pinout: Switched Positive & Location Diesel Engine Technology
No new posts Pinout diagram for 1.7 SDI engine control unit On-Board Diagnostics (OBD)
No new posts MSG Connector Pinout 184Nm 1Z On-Board Diagnostics (OBD)
