Idle speed fluctuates in the semi-warm range
Mc_Givertechnik
2010 Volkswagen T5
Post13-03-2003, 21:17    Subject: Idle speed fluctuates in the semi-warm range Quote
Hello!
Recently, I've noticed fluctuations in the idle speed of my TDI ACV engine. It only happens when the engine is somewhat warm. Also, briefly pressing the accelerator doesn't lower the RPM. So, this phenomenon only occurs at a very specific temperature. What could be the cause? Some value must be incorrect, or could it be related to the disconnected EGR valve??? icon_rolleyes.gif Since my VAG adapter is unreliable, I can't read any error codes. icon_evil.gif
Greetings,
Peter.
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 17-07-2026, 15:05.
Post13-03-2003, 21:34    Subject: Subject: Idle speed fluctuates in the semi-warm range Quote
Mc_Givertechnik wrote:
Recently, I have observed fluctuations in the idle speed of my TDI ACV engine. This only happens when the engine is partially warm. Even a brief press on the accelerator does not lower the RPM. Therefore, this phenomenon occurs only at a very specific temperature. What could be the cause?
Hi Peter,
According to experiences shared in various forums, engine temperature sensors sometimes behave erratically, providing incorrect values only within specific temperature ranges.
icon_idea.gif An increased idle speed is normally regulated when the engine appears to be very cold.
Or if the throttle position sensor is detected as defective... does the car react strangely to the accelerator pedal, or not at all sometimes?
Translated on 17-07-2026, 15:07.
Rudi
Post13-03-2003, 21:47    Subject: Subject: Idle speed fluctuates in the semi-warm range Quote
Hello Peter,
...Even a brief burst of acceleration doesn't reduce the engine speed...
I suspect that what you mean is that the engine speed icon_wink.gif returns to a too-high value even after the foot has been taken off the accelerator.
This strongly suggests the temperature sensor, as Ulf already mentioned. Does your car also take a longer time to warm up when it's in this state?
In the event of a detected sensor failure, the control unit assumes that the engine is cold, initiates the glow plug system (which normally only activates below 10.5°C), and increases the idle speed.
It's possible that the transmitter is experiencing a short circuit or an open circuit to ground at certain temperatures.
Best regards, Rudi.
Translated on 17-07-2026, 15:09.
Mc_Givertechnik
2010 Volkswagen T5
Post14-03-2003, 7:17    Subject: Idle speed fluctuates in the semi-warm range Quote
Hello Rudi, hello Ulf!
"The temperature sensor? I suspected something like that. Otherwise, the car runs pretty well, no noticeable issues."
Which sensor does the control unit obtain this value from? Is it only the water temperature sensor in the radiator, or somewhere else? The temperature reading on the Climatronic display shows correct values, so if it were coming from there, it shouldn't be the air temperature sensor.
Thank you, Peter.
Translated on 17-07-2026, 15:11.
Post14-03-2003, 16:36    Subject: Idle speed fluctuates in the semi-warm range Quote
Hi Peter,
The most important value comes from the coolant temperature sensor.
In this context, the other components likely only serve to justify a (programmed) suspicion of a defect; for example, a disconnected water supply valve won't necessarily improve warm-up performance even with a hot pump.
Translated on 17-07-2026, 15:12.
No new posts Painting Terms: A Comprehensive Glossary Technical Articles
No new posts Audi A2 to A6, Gearbox Area, Customer Goodwill Policy Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A2 to A6, Engine Area, Generosity Policy Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Temperature Reading Fluctuates Diesel Engine Technology
No new posts T4 2.5 TDI: Fuel injection timing fluctuates On-Board Diagnostics (OBD)
No new posts Boost Pressure Fluctuations Diesel Engine Technology
No new posts Idle Speed Fluctuation A4 2.5 TDI Diesel Engine Technology
