strange code on Mahle oil filter - what does it mean
SeatArosa1.7SDI
Post04-05-2004, 22:24    Subject: strange code on Mahle oil filter - what does it mean Quote
Hi!
I stood in front of the shelf in the hardware store, feeling lost among all the Mahle oil filters, and examined all the VW filters. From a threading and flange perspective, they are practically identical, differing only in length and diameter.
For my car, I need relatively thick, short to long ones. The original equipment manufacturer (OEM) filter was a long Bosch filter, while the subsequent filters, ATU always provided a short filter via the part number.
Now I got the long filter 'OC51' because it was hardly more expensive than the short ones, and I think it can hold more dirt.
Now to the question:
1.) Why are there different types of Mahle filters that look absolutely identical on the outside, but differ in price? Different quality?
2.) What does the 5-digit code printed around the filters mean? For the OC51, it's 03 W 37. It almost sounds like motor oil. Are there any µm in there?
I have not found any correlation between the code and the price.
In the Seat operating manual, I couldn't find any specifications for oil filters.
3.) Wie soll ich vorgehen, wenn ich eine große Auswahl an Filtern unterschiedlicher Art und Form für mein Auto habe, aber in der Betriebsanleitung keine Informationen zur Filterauswahl stehen?
Thank you in advance.
Julian
Post05-05-2004, 5:05    Subject: strange code on Mahle oil filter - what does it mean Translating...
http://www.cheesebuerger.de/smilies/schilder/61.gif
SeatArosa1.7SDI
Post08-05-2004, 15:06    Subject: strange code on Mahle oil filter - what does it mean Translating...
[Translating...]Wurde leider bei Google und bei www.mahle.com nicht fündig.
Schade, daß auf meine Ölfilter-Frage nicht so ausführliche Antworten kommen wie bei mehreren parallelen Fragen zur Ölsorte.
Weiß denn niemand etwas über die Qualitäten und Kenngrößen von Ölfiltern und den Vorschriften von Seiten der Fahrzeughersteller?
Wenn irgendjemand irgendetwas über Ölfilter erzählen kann (Erfahrungen, Anekdoten, Links), so möge er sich bitte melden.
Auf http://www.mann-hummel.com/mannfilter/upload/doc/HBEKA_4ayFC.pdf erfuhr ich wenigstens, daß es Filter mit einem Überdruckventil gibt, welches beim Kaltstart (Öl schwer filtergängig) oder verbrauchtem Filter den Filterweg überbrückt. Haben alle Ölfilter dieses Ventil?
danke im voraus
wolfi_b
Post09-05-2004, 10:05    Subject: strange code on Mahle oil filter - what does it mean Translating...
[Translating...]
Ich glaub ich kann zumindest ein wenig weiterhelfen.
Meines Wissens nach haben alle Filter dieses Ventil. Mann kann durch den Anschluss auch die Feder sehen.
Ich hab schon von einem Gutachter gehört das ein Filterproblem zahlreiche Motorschäden zufolge hatte. (Hatte irgendwas mit dem Ventil zutun.) Den Hersteller kenne ich leider nicht. Aber laut dem Gutachter wäre das mit einem Mahle Filter nicht passiert.
Das Ventil öffnet ab einem gewissen Staudruck im Filter. Ich kann mir aber nicht vorstellen wie das beim Starten funktionieren soll.
No new posts Fix Error 00777: Strange Effect? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts seltsamer Durchzugs-Leistungstest a la VAG ? Diesel Engine Technology
No new posts Angebot V6 TDI - was sagt ihr dazu? Diesel Engine Technology
No new posts Strange performance loss on the 1Z Diesel Engine Technology
No new posts C4 TDI AAT, Leistungsverlust, seltsamer Einspritztzeitpunkt Diesel Engine Technology
