AVF with insufficient boost pressure up to 2000 RPM
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Upload
efistho
Post25-09-2010, 17:19    Subject: AVF with insufficient boost pressure up to 2000 RPM Quote
Today, I had a new turbo installed on my Audi by a friendly local workshop.
Unfortunately, nothing works below 2000 RPM.
LOG-01-007-011-2.csv
 File name:  LOG-01-007-011-2.csv
 File size:  3.41 KB
 Downloaded:  1055 times
LOG-01-008-010-1.csv
 File name:  LOG-01-008-010-1.csv
 File size:  2.88 KB
 Downloaded:  994 times
 File size:  2.88 KB
 Downloaded:  865 times
Translated on 06-07-2026, 15:55.
Uwe
Post25-09-2010, 18:54    Subject: AVF with insufficient boost pressure up to 2000 RPM Quote
What does the friendly workshop say about it?
Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
No new posts A3 - AHF: Humming at 2000 RPM Diesel Engine Technology
No new posts Low torque at under 2000 RPM for 81kW TDI engines Diesel Engine Technology
No new posts CAAC shuddering between 1700 and 2000 RPM, only above 65%... Diesel Engine Technology
No new posts V6 TDI Problems: Misfire, Hesitation, Rough Idle On-Board Diagnostics (OBD)
