Data sheet BOSCH LD Sensor 038906051C, Bosch part number 0281002401
Deus Violentia
Post28-09-2010, 21:29    Subject: Data sheet BOSCH LD Sensor 038906051C, Bosch part number 0281002401 Quote
Dear friends,
I am looking for the datasheet for the BOSCH LD sensor 038906051C, Bosch part number 0281002401.
It is used, for example, in 1.9 TDI and 2.0 TDI engines. ASV BKD etc.
I'm specifically interested in the characteristic curve.
@Rainer: Can I use the formula that is listed for the 300 kPa sensors in your shop?
[img][/img]http://www.traderscity.com/board/userpix43/20550-map-sensor-vw--038906051b-038906051c-038906051d-1.jpg{MARKER}
BKD GRF
AHF EBF
Post28-09-2010, 21:46    Subject: Data sheet BOSCH LD Sensor 038906051C, Bosch part number 0281002401 Quote
You have a private message.
No new posts P246E - Exhaust Gas Temperature Sensor (EGS) Bank 1 Sensor 4 General Tips
No new posts Intake Air Temp Sensor P0110: Causes & Fixes General Tips
No new posts P0341 - Camshaft Position Sensor (G40): Implausible Signal Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Motul Datenblatt Upload
No new posts Looking for the datasheet for IHI Turbocharger 24100-3640A Diesel Engine Technology
No new posts BOSCH VP Assembly: Questions & Answers Diesel Engine Technology
No new posts Einstellwerte Reiheneinspritzpumpe BOSCH Diesel Engine Technology
