teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
11-03-2007, 11:06 Subject: Key Fob Programming: How-To Guide |
Hello, since I'm currently unable to proceed with my transmission problem due to a hand injury – I still need to get the RL – I want to program the 2 replacement keys I purchased. The VAG Com  is installed, but (with a 20m cable to the Polo - no), I still need to find a laptop. However, in the search, I only found information for 6N radio keys (Michael II), not for Polo 9N standard keys.
Okay, here's my question: Is the pairing process the same? I don't have a radio remote control, but I have a WFS system. The keys fit, the engine starts, but then immediately shuts off. Is it correct to say that I need to pair the transponder?
What happens if I don't stay within the 15-second timeframe? Will the WFS lock?
Can I then also no longer start the car with my working key?
Please help me, thank you.
derteileklaus
Volkswagen Polo 9N 1.4 PD, manufactured in February 2002.
Translated on 28-09-2026, 3:52.
Profile PM Email Garage |
vagtuning Guest
11-03-2007, 12:00 Subject: Key Fob Programming: How-To Guide |
Do you have the login credentials for the WFS system to register the keys?
Translated on 28-09-2026, 3:54.
11-03-2007, 13:14 Subject: Key Fob Programming: How-To Guide |
Hello Vagtuning, thank you for your feedback.
I think, after reading everything I've read, I probably have to go to VAG with my FGN and politely ask them... right?
derteileklaus
mullemaus Guest
11-03-2007, 14:12 Subject: Key Fob Programming: How-To Guide |
Das wird Dich nicht viel nützen. VAG ist (offiziell) dazu angehalten Wegfahrsperrendaten nicht an Kunden heraus zu geben. Ein Anlernen ist online machbar, auch da nur ohne einsehen des Login-Codes.  Schaue doch mal ob Du evtl den Login-Anhänger noch am Bund dran hast. Von links:
'Engraved login on plastic trailer, back of login trailer, extra metal trailer (not related to the login).'
Translated on 28-09-2026, 3:55.
11-03-2007, 14:41 Subject: Key Fob Programming: How-To Guide |
Thank you, Mulle.
I was frantically searching for the trailer, but found nothing. I eventually found your hint in the search results, and I also read about the online posting option without displaying the code.
It's broken now. I guess I'll have to get it fixed by the dealer!
I'll probably need the VAG-Com again sometime, even though it didn't help this time.
Thank you for all your efforts.
derteileklaus
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
mullemaus Guest
11-03-2007, 14:50 Subject: Key Fob Programming: How-To Guide |
If your dealer is nice, they might try to retrieve the login information via fax.
Translated on 28-09-2026, 3:56.
11-03-2007, 16:10 Subject: Key Fob Programming: How-To Guide |
Okay, then I'll try it out next week. I know someone there who can be friendly.
See you later.
Okay, here's the translation:
"I was actually thinking of trying Quitz, but are there any beginner-friendly tutorials available, or are they only for more advanced users? Can anyone tell me?"
Translated on 28-09-2026, 3:57.
mullemaus Guest
11-03-2007, 16:27 Subject: Key Fob Programming: How-To Guide |
One more question: I wanted to try Quitz, but there are no posts, or maybe just not for beginners like me? Who can tell me?
Then, why don't you create a quiz, or send me the question-and-answer images and I'll post it for you  ?
11-03-2007, 18:37 Subject: Key Fob Programming: How-To Guide |
A little easier to recognize than the pictures of Mulle...
Translated on 28-09-2026, 3:58.
DieselBär30x Profi-Schrauber
Joined: 01/17/2008 Posts: 3560 Karma: +101 / -0 Location: München & Passau
20-11-2010, 11:22 Subject: Key Fob Programming: How-To Guide |
*dust off*
Hello everyone!
Now I'm facing the same problem: I'm too inexperienced to learn a third key for my T5 using VCDS.
The vehicle was handed over to me with 3 keys (2x remote keys, which function, and 1x a key without remote functionality, with the WFS symbol and the filament blinking). I never tried the third key. It fits mechanically, but it activates the WFS (Wireless Keyless System) and creates error entries in the engine control unit (ECU).
Two learned keys are stored in the AI.
In Sebastian's picture, you can see the black plastic tag. Mine, on the other hand, has a black sticker on one side instead of a barcode, with the last 7 digits of the VIN. On the other side, like in the picture on the left, I have a white sticker with 2 digits at the top and 5 digits below. The area on the right (the scratch-off section) is completely missing from mine, and it doesn't appear to have been scratched off.
If I try the first sequence of digits (padded with leading zeros) as a login, a brief connection interruption occurs, followed by the VCDS message "Login lost due to connection interruption!" (or similar). The same thing happens with the second 5-digit sequence.
"Do I need to request the login online from VW? Did the previous owner remove the scratch-off login, or was that the status when the car was delivered in 2004? How is it possible that a car is delivered with 3 keys, but only 2 are programmed?"
Thank you very much in advance for your help!!
Best regards from Munich!
P.S. My plastic charm is not in two pieces or foldable, and I don't have the metal charm at all.
Translated on 28-09-2026, 4:00.
Joined: 04/12/2002 Posts: 18131 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
20-11-2010, 12:01 Subject: Key Fob Programming: How-To Guide |
HI,
Please send me a picture via direct message.
Translated on 28-09-2026, 4:02.
Profile PM WWW Garage |
Deus Violentia Schrauber
20-11-2010, 13:47 Subject: Key Fob Programming: How-To Guide |
To the best of my knowledge, the scratch-off login system has been discontinued for a very long time, at least since Immo3, which would be around 2001/2002.
Only VW tools or specialized tools will help with that. Please contact me privately if you need more information.
@Teilekalus: If you still need a diagnostic tool, I definitely have some very good deals for you on hardware! - Feel free to send me a private message if you're interested.
BKD GRF
AHF EBF
Translated on 28-09-2026, 4:03.
20-11-2010, 14:11 Subject: Key Fob Programming: How-To Guide |
Thank you, I have received a Lap-solution in the meantime, which was already from March 2007. But it's nice that you thought of me.
Translated on 28-09-2026, 4:04.
20-11-2010, 16:31 Subject: Key Fob Programming: How-To Guide |
BKD GRF
AHF EBF
20-11-2010, 20:59 Subject: Key Fob Programming: How-To Guide |
Hello everyone again!
Deus, thank you for the info! ...that means I can try a lot of different things  .
I thought that for vehicles where there is no "key ring" included, the login would have to be requested online, but as they say, you never stop learning  .
20-11-2010, 23:52 Subject: Key Fob Programming: How-To Guide |
"In the past, VAG (Volkswagen Group) could send a fax with the VIN (Vehicle Identification Number), and 15 minutes later, a fax would be returned with the PIN (Personal Identification Number). This PIN, in conjunction with the dealer and importer number, was then valid for 24 hours. Later, Audi switched to an online query system using a diagnostic tool, where the tool itself retrieves the VIN from the control unit and connects to the network. VW also adopted this system later (around 2004/2005), and since then, fax requests have been discontinued."
The pin is also no longer visible when using the tester to connect to it, as previously mentioned.
There are specialized tools that can read the PIN from the control unit via the OBD socket, and this applies to virtually all VAG vehicles. These tools can also be used to program keys via VCDS. In some cases, it is also possible to remove the control units/tachometers and send them in for this purpose.
BKD GRF
AHF EBF
Translated on 28-09-2026, 4:06.
