Touareg 7L - Need help with coding the onboard network AFL
Flow Tech
Post15-11-2010, 0:47    Subject: Touareg 7L - Need help with coding the onboard network AFL Quote
Unfortunately, I'm having a problem with the encoding of the on-board network!
A friend of mine borrowed my VCDS and messed something up in the coding for module 09!
Since then, his AFL (Automatic Fire Lighter) has stopped working in the "Auto" position.
Perhaps someone can tell me the original encoding.
I have tried using the Lange Coding Assistant multiple times, but unfortunately, without success.
Partially, there was no option to choose regarding Lange.
Thank you very much for your help!
Sunday, November 14, 2010, 4:47:03 PM: 36856
VCDS Version: RKS 10.6.1
Data as of: 20100901.
FloW Tech
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 7L - VW Touareg.
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
Vehicle Identification Number: WVGZZZ7LZ5D065741 Mileage: 116750 km
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Label file: RKS\070-906-016-BAC.lbl
Part number SW: 070 906 016 BL Hardware number: 028 101 185 9
Part: R5 2.5L EDC G000AG 7001
Revision: 12345678 Serial number: VWZ3Z0E1315935
Encoding: 0011175
Operating number: WSC 66565 257 00032
VCID: 5BB1E5F5E357
No errors found.
Readiness: 0 0 X X X
Address 02: Transmission Label file: RKS\09D-927-750.lbl
Part number: 09D 927 750 BP
Part: AL 750 6A 0596
Encoding: 0004136
Operating number: WSC 31414 000 00000
VCID: 7DF58B6D5D83
No errors found.
Address 03: Brakes Label file: 7L0-907-379-MK25.lbl
Part number: 7L0 907 379 G.
Component: ESP ALL-WHEEL DRIVE MK25 0203
Encoding: 0006402
Operating number: WSC 22641 146 02737
VCID: 3D754B6D1D03
No errors found.
Address 05: Access/Startup. Label file: RKS\3D0-909-135.lbl
Part number SW: 3D0 909 135 N, HW: 5WK 470 21.
Component: Kessy 6610
Revision: 66105312 Serial number: VWZ3Z0E1315935
Encoding: 0000232
Operating number: WSC 72893 146 82353
VCID: 306B6259DA51
Part number: XXXXXXXXXXX
Component: ELV XXXX
No errors found.
Address 08: Climate/Heating Label file: None
Part number: 7L6 907 040 H
Part: CLIMAtronic R/L X 3716
Encoding: 0000030
VCID: 3565534D2533
No errors found.
Address 09: Body Control Module
Label file: RKS\7L6-937-049.lbl
Part number: 7L6 937 049 N
Component: 3001
Encoding: 0038133
Operating number: WSC 22624 146 82333
VCID: 479929854FDF
No errors found.
Address 15: Airbag
Label file: 3D0-909-601.lbl
Part number: 3D0 909 601 F
Part number: 0B Airbag 8.4E+ H11 1151.
Encoding: 0012354
VCID: 26478401E895
No errors found.
Address 16: Steering wheel
Label file: RKS\7L6-953-549.lbl
Part number: 7L6 953 549 D
Component: Steering column module 3301.
Encoding: 0000031
VCID: 408B32996AF1
No errors found.
Address 17: Combination instrument
Label file: RKS\7L6-920-xxx-17-7LA.lbl
Part number: 7L6 920 881 A
Component: COMBINATION INSTRUMENT RB8 3135
Encoding: 0007111
Operating number: WSC 72893 146 80234
VCID: 366754413835
No errors found.
Address 18: Auxiliary heater
Label file: RKS\7L6-819-008.lbl
Part number: 7L6 815 071 C.
Component: Standheizung E1MAC (Parking heater E1MAC)
Encoding: 0000000
VCID: 326F6851D45D
No errors found.
Address 19: CAN-Gateway Label file: RKS\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway K<->CAN 0101.
Encoding: 0000006
VCID: F0EB22599AD1
No errors found.
Address 22: All-wheel drive
Label file: RKS\0AD-927-755.lbl
Part number: 0AD 927 755 BE.
Part: TRANSFER CASE 0122
Operating Number: WSC 00000 000 00000
VCID: 7F097165578F
No errors found.
Address 29: Left-side lighting control. Label file: 3D0-909-157.lbl.
Part number: 3D0 909 157.
Component: EVG GDL+AutoLWR(l) 0001
Encoding: 0000003
VCID: E6C74401A815
No errors found.
Address 32: Lock electronics
Label file: None
Part number: 0AC 927 771 C
Component: SG Crossbar, Part Number: 5020.
VCID: 387B5A793221
No errors found.
Address 34: Level control Label file: None
Part number: 7L0 907 553 F
Part: AIR FILTER - CDC - 3C3P1 3081
Encoding: 0015521
VCID: 366754413835
No errors found.
Address 37: Navigation
Label file: RKS\7L6-919-887-CD.lbl
Part number: 7L6 919 887 K
Component: Navigation 0634
Encoding: 0000004
VCID: 4E971CA1A0A5
No errors found.
Address 39: Right-side lighting control.
Label file: 3D0-909-158.lbl
Part number: 3D0 909 158.
Component: EVG GDL+AutoLWR(r) 0001
Encoding: 0000003
VCID: E7D94905AF1F
"1 error found:"
01344 - Gas discharge lamp.
012 - Electrical fault in the circuit - Intermittent.
Address 46: Comfort System
Label file: 7L0-959-933.lbl
Part number: 7L0 959 933 E.
Component: 2L HSG 0201
Encoding: 0000085
VCID: 3E774C611005
Part number: 7L0 959 701 G
Component: Door control unit FS 0201.
Part number: 7L0 959 702 G
Component: Door control unit BF 0201.
Part number: 7L0 959 703 C.
Component: Door control unit HL 0201.
Part number: 7L0 959 704 C
Component: Door control unit HR 0201.
Part number: 7L0 907 719.
Component: Tilt sensor 0020
Part number: 7L6 951 171.
Component: A, Interior sensor, 0019.
No errors found.
Address 56: Radio Label file: RKS\7L6-035-186-CD.lbl
Part number: 7L6 035 186 A
Component: Radio 0634
Encoding: 0027447
VCID: 316D675DD15B
No errors found.
Address 68: Wiper electronics. Label file: None.
Part number: 7L0 955 119 K
Component: Front Wiper 4027
Encoding: 0000855
Operating number: WSC 31414 000 376832
VCID: 3C7346690619
Part number: 1K0 955 559 M
Part number: RegenLichtSens 005 0605.
Encoding: 00217126
No errors found.
Address 76: Parking Assist
Label file: RKS\3D0-919-283.lbl
Part number: 7L0 919 283 F
Part number: 0E Parking Assist System 1107.
VCID: 397D5F7D092B
No errors found.
Address 77: Telephone Label file: None
Part number SW: 7L6 035 729 F, Part number HW: 7L6 035 729 F.
Component: FSE_275x H18 0020
Revision: 00000001 Serial number: 00000000185883
Encoding: 0000311
Operating number: WSC 22659 146 83363
VCID: 397D5F7D092B
No errors found.
End.
Translated on 07-07-2026, 22:25.
mullemaus
Post15-11-2010, 1:25    Subject: Re: Touareg 7L - Need help with coding the onboard network AFL Quote
Since then, his AFL (Automatic Fire Lighter) has stopped working in the 'Auto' position.
Bedanke mich vielmals für Eure Hilfe!
The ORIGINAL data is stored in a 'backup log.' For completely painless icon_lol.gif icon_wink.gif, you can find it at: C:\Kaufmann\VCDS-RKS-GER\Debug and then in the CodingLog.TXT icon_wink.gif.
Translated on 07-07-2026, 22:45.
Flow Tech
Post15-11-2010, 1:48    Subject: Touareg 7L - Need help with coding the onboard network AFL Quote
Thanks, Mulle!
The correct code should be 0103676!
It's great to have such professionals on board!
Greetings FloW.
Translated on 07-07-2026, 22:46.
Ross-Tech-Support
Post15-11-2010, 22:53    Subject: Re: Touareg 7L - Need help with coding the onboard network AFL Quote
Changing the coding from 0038133 to 0103676 doesn't make much sense upon closer inspection. According to the VIN, the vehicle was produced for the German market, which means that some features were simply never active from the factory.
- Daytime running lights active (not optional).
- Headlights activated for USA/Canada.
- Comfort interior lighting enabled.
- Electric load management enabled.
The last two points still make sense, but the first two are less likely to be normal for a vehicle in Germany.
Code:
Adresse 39: Lichtsteuerung re.        Labeldatei: 3D0-909-158.lbl
   Teilenummer: 3D0 909 158
   Bauteil: EVG GDL+AutoLWR(r)  0001
   Codierung: 0000003
   Betriebsnr.: WSC 31414 000 00000
   VCID: E7D94905AF1F
1 Fehler gefunden:
01344 - Gasentladungslampe
            012 - elektrischer Fehler im Stromkreis - Sporadisch
Perhaps it's time to take a closer look at the error in the LWR. icon_wink.gif
Translated on 07-07-2026, 22:47.
No new posts Doku Touareg, Transmission in Emergency Mode Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touareg documentation, clacking sounds coming from the st... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dacia/Renault Duster, squeaking noises steering column / ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Caddy: Onboard Network Coding Problem Solution Electrical Systems, Vehicle Electronics, Multimedia
No new posts Touareg V10: Bleed Additive System (Coding II) On-Board Diagnostics (OBD)
No new posts VP37 (ALH): Get Help & Solutions Now! Diesel Engine Technology
No new posts Need urgent help... Loss of power... Diesel Engine Technology
