Stummel Guest
13-12-2010, 0:25 Subject: VAG connector contacts. |
Hi.
'Until about a year ago, I mostly worked on older cars (roughly up to the G3 generation), and Volkswagen usually used a specific type of connector. I even bought a set of connectors and a release tool for those.'
'However, with the 2010 Scirocco, I didn't need to use a contact, and the situation isn't any better with the 2006 Touran...'
The question now is what are the names of these pins, and what unlocking tool is needed for them? I find the solution using the pre-crimped repair leads from VW to be quite unsatisfactory, as it still requires a connection with a solder joint.
| Description: |
| File size: |
65.52 KB |
| Viewed: |
3429 times |
| Description: |
| File size: |
120.96 KB |
| Viewed: |
3711 times |
Translated on 08-07-2026, 11:01.
Boro Guest
13-12-2010, 8:12 Subject: VAG connector contacts. |
The pins are also available for purchase individually, in various sizes. You don't necessarily have to use the pre-made connectors.
Translated on 08-07-2026, 11:02.
Stummel Guest
13-12-2010, 19:33 Subject: VAG connector contacts. |
'At VW? If I don't use a parts number to find something, it won't work. He only finds the repair cable because AKTE 'gives it to him'.'
'Actually, I didn't really want to buy it from VW, but rather from a place like Herth+Buss or something similar.'
Translated on 08-07-2026, 11:03.
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2403 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
13-12-2010, 22:12 Subject: VAG connector contacts. |
If you're already "feeding" him all this information, then when you're "chewing" through the electronics model, pay attention to the pages immediately before the individual wires. You'll find the individual contacts there as well. Compare the pictures and dimensions, and you'll have your contact.
If you can't find it yourself, then at least give us the part number of the individual cable. We'd also appreciate it if you could provide the corresponding dimensions.
Guste.
Profile PM Garage |
Stummel Guest
14-12-2010, 0:28 Subject: VAG connector contacts. |
Okay, I gave him the part number for the housing. Then, with a single click, AKTE (a parts catalog software) shows the corresponding repair cables. He then found them himself.
'I'm having trouble finding the pin. The cable attached to the connector has a marking of 000-979-242-e, and it's 2.5mm² in diameter. It's supposed to go into the electrical box in the engine compartment of a 2010 2.0L Scirocco.'
Translated on 08-07-2026, 11:04.
Holger247 Schrauber
Joined: 11/05/2002 Posts: 259 Karma: +0 / -0 Location: Böblingen
08-01-2011, 0:39 Subject: VAG connector contacts. |
A good overview of connectors, repair cables, etc. is usually available at Passatplus.
However, it's possible that this plug is not included, as it might be a newer model.
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 08-07-2026, 11:05.
