G62 at the ASZ in the Seat Ibiza
Ibi6L-ASZ
2004 Seat Ibiza
Post23-01-2011, 19:08    Subject: G62 at the ASZ in the Seat Ibiza Quote
Hello everyone!
I'm having a problem where my coolant temperature sensor occasionally shorts out, which causes an error to be logged in the MSG (presumably a vehicle's diagnostic system). Furthermore, I've also noticed a slightly increased fuel consumption since the error started.
I wanted to replace this part now (I have a replacement ready), but I can't find it anywhere. Unfortunately, the Ibiza also has a very cramped engine compartment.
I would really appreciate it if someone could locate the G62 in the attached images, so I know exactly where to look.
Thank you in advance!
 File size:  996.25 KB
 Viewed:  1499 times
 File size:  1016.4 KB
 Viewed:  2088 times
BMW 123d Coupe
Post23-01-2011, 20:06    Subject: G62 at the ASZ in the Seat Ibiza Quote
It is located on the rear right side of the cylinder head and has a 4-pin connector.
Post23-01-2011, 21:55    Subject: G62 at the ASZ in the Seat Ibiza Quote
and it's really not possible to swap the gift. Look at it with a mirror, angled slightly below the tandem pump. It's installed facing in the direction of travel. Be careful with the retaining clip. If it falls off, you'll need to remove the lower engine cover.
Post24-01-2011, 17:38    Subject: G62 at the ASZ in the Seat Ibiza Quote
, as viewed from the front icon_wink.gif.
No, only 2-pin! The AI receives the water temperature data from the MSG via CAN.
Post24-01-2011, 18:55    Subject: G62 at the ASZ in the Seat Ibiza Quote
No, only 2-pole! The AI receives the WaTemp data from the MSG via CAN.
Oh, thank you for the information!
No new posts Electrical problem in wet conditions, Seat Ibiza 6L ASZ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Ibiza 6L error code 16415 - Bank 1, Sensor 1; Heater... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Speed Control Retrofit Seat Ibiza / Polo Troubleshooting & Guides
No new posts VCDS error message on a Seat Ibiza 1.6 TDI CR, year 2010 Upload
No new posts GRA und Seat Ibiza Bj 11/98 Diesel Engine Technology
No new posts Startprobleme Seat Ibiza (AHU) Diesel Engine Technology
No new posts Seat Ibiza Service Interval Display 6J1 On-Board Diagnostics (OBD)
