Fuel Injector Cable Clip - Pump Wiring Harness
captaindickei
Karma: +1 / -1   Thank you, like it!
Post14-06-2011, 23:00    Subject: Fuel Injector Cable Clip - Pump Wiring Harness Quote
Today, I had to disconnect the pump-injector connector from the engine block on an Audi A3 2.0 TDI. (This is the round connector that you have to turn.)
Unfortunately, the small plastic pin that secures the closure has fallen directly into the engine compartment.
I understand that the wiring harness is still securely locked in place, even though this plastic pin wasn't used in the Golf 4 TDI.
Do you know if this part can be ordered separately?
I hope it's clear what I mean.
"Hello"
Translated on 30-08-2026, 0:02.
No new posts P261A, P261B - Pump for coolant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Headlight Washer Pump Leak - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing injector nozzles in common rail injectors Troubleshooting & Guides
No new posts Are the AFN and AHU cable harnesses identical? Diesel Engine Technology
No new posts ESP Wiring Harness for AFN TDI Engine Diesel Engine Technology
No new posts AFN Wiring Harness Pinout T68 Connector Diesel Engine Technology
No new posts Wiring harness, front passenger door, door unlocking Electrical Systems, Vehicle Electronics, Multimedia
