Ford Mondeo: Shaking & White/Blue Smoke - Causes & Fixes
j.gismo
Registered VCDS User
Post20-05-2011, 7:20    Subject: Ford Mondeo: Shaking & White/Blue Smoke - Causes & Fixes Quote
"Hi, does anyone have experience with Ford? I'm usually a VW mechanic, but I'm dealing with a 2005 Mondeo 2.2 TDCi that's having problems with its engine running smoothly. When it starts, it runs well (cold engine). However, when you increase the RPM slightly, without any load, to around 1200 RPM, the engine starts to run unevenly and smokes heavily from the exhaust (diesel). The suspected camshaft sensor is gray, although I can't understand how it could be related. However, it has been reported in other forums."
Translated on 04-10-2026, 1:56.
Alukugel
Post08-06-2011, 12:50    Subject: Ford Mondeo: Shaking & White/Blue Smoke - Causes & Fixes Quote
The EGR valve often causes problems with this engine.
j.gismo
Post08-06-2011, 19:39    Subject: Ford Mondeo: Shaking & White/Blue Smoke - Causes & Fixes Quote
Okay, I also suspected the valve. I closed it, but there was no change. Has anyone had problems with the injectors?
Translated on 04-10-2026, 1:57.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post17-06-2011, 16:19    Subject: Ford Mondeo: Shaking & White/Blue Smoke - Causes & Fixes Quote
"Years ago, we had a 2.0 96kW TDCI with a faulty injector. It always ran unevenly and lacked power, not just when it was warm. However, because it was so long ago, I don't know if any error codes were set. In any case, the problem was detected during a fuel return test. This Ford has a Delphi injection system, and this particular injector was not available for purchase from general retailers. However, Ford sold it for around 70 euros. Ultimately, the injector had to be programmed using a KTS diagnostic tool."
An injector was replaced, and the machine started working again.
Passat Variant BGW 2005
No new posts Ford Focus 1.6 TDCi - Error code P1181 General Tips
No new posts Airtronic D2 Defective: Troubleshooting Smoke Issues General Tips
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Ford Mondeo 2.0 TDCi - where to tap into the turbo boost ... Diesel Engine Technology
No new posts Jag X-Type 2.0D Turbocharger Problem? Diesel Engine Technology
No new posts Mondeo TDCI won't start. Diesel Engine Technology
No new posts Ford Mondeo: Won't Start After Empty Tank? On-Board Diagnostics (OBD)
