Startwölkchen bei PD: Is it common?
Klausel
Post15-07-2011, 22:53    Subject: Startwölkchen bei PD: Is it common? Quote
Our AXR engine (2006, Euro4, no DPF) has normal oil consumption and good performance.
and readings of 13, 18, and 23 are completely normal.
But it almost always makes a noise when starting with a slightly warm engine.
Very subtle, yet noticeable, clouding (color is more towards dark).
My almost 10-year-old Euro2 AFN is a perfect example in this regard.
Even before the DPF (Diesel Particulate Filter) was installed, there was practically never any visible smoke.
Does the PD generally tend to exhibit this behavior?
I would appreciate any experiences you can share.
Best regards, Klaus.
Polo 6R, TSI 110 PS
Translated on 29-10-2026, 18:05.
Post16-07-2011, 8:47    Subject: Startwölkchen bei PD: Is it common? Quote
Hello Klaus,
No, I cannot confirm such a tendency.
If the exhaust smoke is more black, it could be due to a coolant temperature sensor that is sending too low a temperature reading to the engine control unit.
When dealing with gray smoke, the likely causes are either a faulty turbocharger seal (specifically, the bearing area, where oil can accumulate in the intake manifold) or the cylinder head (worn valve guides/valve seals).
Translated on 29-10-2026, 18:07.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post17-07-2011, 18:23    Subject: Startwölkchen bei PD: Is it common? Quote
Hi Klaus, I also occasionally see a small, dark cloud during the ATD (Abgas-Temperatur-Diagnose) at startup. I suspect that, under certain operating conditions, the starting amount is quite significant icon_biggrin.gif, but there's no need to worry.
reflexsilber met.
Translated on 29-10-2026, 18:08.
No new posts CR general - Rail pressure too high Diesel Engine Technology
No new posts Problem with an ATM Diesel Engine Technology
No new posts Fitting a rear subframe from an Audi A6 into a Golf? Diesel Engine Technology
No new posts VW Golf 3.0 TDI: Questions & Answers On-Board Diagnostics (OBD)
