AFS coding for Seat Altea
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Haar2k
Registered VCDS User
Post02-05-2011, 21:43    Subject: AFS coding for Seat Altea Quote
I would like to retrofit my Seat Altea with bi-xenon headlights including cornering lights. Okay, I now need the correct encoding for the AFS control unit and the power modules.
Can someone help me with this?
VCDS Version: RKS 10.6.3
Data as of: 20110306.
Monday, May 2, 2011, 18:01:33:12405
Vehicle type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 62 69 72 7D
Vehicle Identification Number: VSSZZZ5PZ6R018405 Mileage: 148,390 km
00-Steering angle sensor -- Status: OK 0000
01-Motor -- Status: OK 0000
03-Brakes -- Status: OK 0000
08-Climate/Heating -- Status: OK 0000
09-Onboard network -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-inch steering wheel -- Status: OK 0000
17-in-1 instrument -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-way immobilizer -- Status: OK 0000
42-door electric. Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric. Front passenger seat. -- Status: OK 0000
55-Beam adjustment. -- Status: Error 0010.
62- Door, electric, left and right -- Status: OK 0000
69-inch cable -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000
7D Auxiliary Heater -- Status: OK 0000
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Label file: RKS\03G-906-016-BKD.lbl
Part number SW: 03G 906 016 HE HW: 028 101 229 1
Part: R4 2.0L EDC G000SG 7000
Revision: 12345678 Serial number: SEZ7Z0E3107016
Encoding: 0050072
Operating number: WSC 06402 785 00200
VCID: 6DD59EA40D17
No errors found.
Readiness: 0 0 1 1 1
Address 03: Brakes Label file: RKS\1K0-907-379-MK60-F.lbl
Part number SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Encoding: 0006898
VCID: 408B17106A05
No errors found.
Address 08: Climate/Heating Label file: RKS\1K0-907-044.lbl
Part number: 5P0 907 044 B
Part number: Climatronic PQ35 006 0203
Operating Number: WSC 00000 000 00000
VCID: 2F6944ACC79B
No errors found.
Address 09: Body Control Module
Label file: RKS\3C0-937-049-30-H.lbl
Part number SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: On-board network module H54 2202.
Revision: 00H54000 Serial Number: 01000007592409
Encoding: A3884E0700000000102D0000000000000009FD0B0040010C000000000000
Operating number: WSC 35110 377 08192
VCID: 71ED82D4112F
Part number: 5P0 955 119 B.
Part: Wiper SE359 012 0402
Encoding: 00056272
No errors found.
Address 15: Airbag
Label file: RKS\1K0-909-605.lbl
Part number SW: 1K0 909 605 N, Hardware number: 1K0 909 605 N.
Part: S3 AIRBAG VW8 015 2100
Revision: 03015000 Serial Number: 0038ED0GJN9J
Encoding: 0021299
VCID: 37797CCC3FCB
No errors found.
Address 16: Steering wheel
Label file: RKS\1K0-953-549-MY8.lbl
Part number SW: 1K0 953 549 AG Hardware number: 1K0 953 549 AG
Part: J0527 034 0070
Encoding: 0002042
VCID: 77F9BCCC7F4B
Part number: XXXXXXXXXXX
Part: E0221 004 0060
No errors found.
Address 17: Combination Instrument
Label file: RKS\1K0-920-xxx-17.lbl
Part number: 5P0 920 823 B
Component: COMBINATION INSTRUMENT VO3 0616
Encoding: 0004101
Operating number: WSC 93103 474 95794
VCID: 2F6944ACC79B
No errors found.
Address 19: CAN-Gateway Label file: RKS\1K0-907-530.lbl
Part number SW: 1K0 907 530 F, HW: 1K0 907 951.
Component: Gateway H10 0120.
Revision: H10
Serial number: 2800105625952C
Encoding: 7D3F4B00078202
VCID: 2A5F55B8FC79
No errors found.
Address 25: Immobilizer
Label file: RKS\1K0-920-xxx-25.lbl
Component: IMMO VO3 0616
VCID: 2F6944ACC79B
No errors found.
Address 42: Door electronics. Driver Label file: RKS\1K0-959-701-MAX2.lbl
Part number: 1T0 959 701 C.
Part: Door Seal 024 2431
Encoding: 0000144
VCID: 37797CCC3FCB
No errors found.
Address 44: Steering Assist
Label file: RKS\1Kx-909-14x.lbl
Part number: 1K1 909 144 J.
Component: EPS_ZFLS, Class 5, D04 1606.
VCID: 326F4DD8D4A9
No errors found.
Address 46: Comfort System
Label file: RKS\1K0-959-433-MIN.clb
Part number: 1K0 959 433 AK
Component: KSG 0401
Encoding: 18D000D82D000505084F090000CC
Operating number: WSC 33103 476 07781
VCID: 79FDBAF4495F
Component: Sounder, not mounted.
Component: NGS, not mounted.
Component: IRUE, not mounted.
No errors found.
Address 52: Door electric, passenger side. Label file: RKS\1K0-959-702-MAX2.lbl
Part number: 1T0 959 702 C
Encoding: 0000144
VCID: 387B7FF032D5
No errors found.
Address 55: Headlight range adjustment. Label file: RKS\5M0-907-357-V2.lbl
Part number SW: 5M0 907 357 C. Hardware: 5M0 907 357 C.
Component: AFS Control Unit 0142
Revision: 00H04000 Serial Number:
Encoding: 1180802
Operating number: WSC 01316 111 20184
VCID: 34634BC02EBD
Part number: 7L6 941 329 A
Component: AFS-Lst. Module l 0004
Encoding: 00000035
Part number: 7L6 941 330.
Component: AFS-Lst. module r X018
Encoding: 00000034
4 errors found:
01042 - Control unit not coded.
000 - - - Warning light ON.
Environmental conditions:
Error status: 11100000
Error priority: 2
Error frequency: 1
Lost Count: 131
Time: 0
invalid
invalid
invalid
02656 - Headlight module, left side (J667), not coded.
Error priority: 2
Error frequency: 1
Lost Count: 131
Time: 0
invalid
invalid
invalid
02657 - Headlight module, right side (J668)), not coded.
Error priority: 2
Error frequency: 1
Lost Count: 131
Time: 0
invalid
invalid
invalid
01539 - Headlights not adjusted.
005 - No or incorrect initial setting/adaptation - Warning light ON.
Error status: 11100101
Error priority: 3.
Error frequency: 1
Lost Count: 131
Time: 0
invalid
invalid
invalid
Address 62: Door opener, left and right. Label file: RKS\1K0-959-703-GEN2.lbl
Part number: 1K0 959 703 E.
Component: Door Seal 021 2426
Encoding: 0000144
VCID: 326F4DD8D4A9
No errors found.
Address 69: Trailer (J345) Label file: RKS\1K0-907-383-MY8.lbl
Part number SW: 1K0 907 383 F, HW: 1K0 907 383 F.
Part: Trailer H09 0100
Revision: 3A001001 Serial Number: 00000144953027
Encoding: 0100000100000000
VCID: 306B47D0DAA5
No errors found.
Address 72: Door opener, right side. Label file: RKS\1K0-959-704-GEN2.lbl
Part number: 1K0 959 704 E
Encoding: 0000144
VCID: 336148DC2BB3
No errors found.
Address 7D: Auxiliary Heater
Label file: RKS\1K0-963-235.lbl
Part number SW: 1K0 963 235 E, Hardware number: 1K0 963 235 E.
Component: PTC element 0404
Revision: 00800000 Serial Number:
VCID: 2D555EA4CD97
No errors found.
End.
Post03-05-2011, 13:50    Subject: AFS coding for Seat Altea Quote
Haieiai.
Part number: 7L6 941 329 A.
Encoding: 00000035
Component: AFS-Lst. module for X018.
Encoding: 00000034
Why did you collect such different parts icon_question.gif?
I can offer you my (coding) services.
Address 55: Headlight range adjustment. Label file: RKS\5M0-907-357-A.lbl
Part number SW: 5M0 907 357 A, Hardware: 5M0 907 357 A.
Component: AFS Control Unit X014
Revision: H01 Serial Number:
Encoding: 2301953
Operating number: WSC 05311 000 00000
VCID: 32608A8AD4A9
Part number: 7L6 941 329.
Component: AFS-Lst. Module l X018
Encoding: 00000035
Encoding: 00000035
or
Address 55: Headlight range adjustment. Label file: RKS\5M0-907-357.lbl
Component: AFS Control Unit 0136
Encoding: 2311169
Encoding: 00000035
Component: AFS-Lst. module r 0004
Encoding: 00000035
Ross-Tech-Support
Post04-05-2011, 10:57    Subject: AFS coding for Seat Altea Quote
"Last modules with different hardware/software versions are very likely to be incompatible. Moreover, since the installed 7L6-941-330 @ X018 part number doesn't match the master unit's production date, you will probably not be able to get it correctly coded."
The coding values mentioned by dieselmartin are for different versions in the VW Passat (3C) and are not compatible with the Seat Altea (5P). The correct coding for this master unit would be 2556933, but it is very likely not compatible with the subsystem/slave.
Haar2k
Post04-05-2011, 11:14    Subject: AFS coding for Seat Altea Quote
Thank you very much.
I'll test the encoding and report back.
Ross-Tech-Support
Post13-08-2011, 2:24    Subject: AFS coding for Seat Altea Quote
No new posts Seat Altea horn not working, cruise control Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Codierung des APS bei Audi Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Altea; GRA-Kontrollleuchte fehlt?! Diesel Engine Technology
No new posts Strlp. Klemme 30 am MotorSTG - Seat Altea Electrical Systems, Vehicle Electronics, Multimedia
No new posts Seat Altea 5P rear wiper out of order Electrical Systems, Vehicle Electronics, Multimedia
No new posts Codierung Seat ABS-Steuergerät On-Board Diagnostics (OBD)
