VAG EDC15VM+ Pinout: Complete Wiring Diagram
schwebomat
Registered VCDS User
Post05-09-2011, 8:24    Subject: VAG EDC15VM+ Pinout: Complete Wiring Diagram Quote
Good day, dear community,
I have a TDI engine here that I'm using as a stationary engine. I urgently need the pinout diagram for the engine control unit, especially the pins for the throttle position sensor.
Can someone help me with this? I've already searched the forum and Google, but I only found the pin assignments for OBD programming for this control unit icon_sad.gif.
Translated on 10-08-2026, 19:55.
vwSchrauber
Post05-09-2011, 12:41    Subject: VAG EDC15VM+ Pinout: Complete Wiring Diagram Quote
The engine control unit belongs to an ALH engine, and as far as I remember, it was installed in an Octavia (012H -> ALH, 012HC -> ASV).
Have someone with access to Autodata look up the wiring diagrams for you icon_wink.gif.
Translated on 10-08-2026, 19:56.
schwebomat
Post05-09-2011, 13:01    Subject: VAG EDC15VM+ Pinout: Complete Wiring Diagram Quote
Hello there!
yep, it was an Octavia engine icon_smile.gif.
Does anyone here have AutoData? I don't know anyone else who has it icon_sad.gif.
Best regards and thank you!
Post05-09-2011, 13:08    Subject: VAG EDC15VM+ Pinout: Complete Wiring Diagram Quote
Self-help would involve http://erwin.volkswagen.de finding the corresponding wiring diagram.
Various "Do-it-yourself" books often include corresponding electrical diagrams in the back, and the cost of acquiring an older copy is likely to be quite reasonable.
Translated on 10-08-2026, 19:57.
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Pinout for control unit 1Z? On-Board Diagnostics (OBD)
No new posts Wiring diagram for the AAT control unit in the Audi 100 On-Board Diagnostics (OBD)
No new posts ABS Control Unit Pinout: Find Your Diagram On-Board Diagnostics (OBD)
No new posts OBD connector pinout and control unit On-Board Diagnostics (OBD)
