Part Number Original PD Fuel Injectors
Fabia.S
Post29-09-2011, 18:13    Subject: Part Number Original PD Fuel Injectors Quote
It's probably time to replace the fuel injectors on my Fabia, but they need to be replaced with the original ones.
But somehow, only tuning nozzles are apparently offered, which I cannot accept because they are already almost at the maximum. Nm achieved and no further modifications to the control unit are intended.
Does anyone know the part number for the ATD nozzles, possibly for the successor AXR?
Unfortunately, it seems that most companies are primarily interested in selling complete injection molding components, ideally new, at the appropriate price.
Fabia 1.9 Combi, Bj. 2001,ATD Euro 3
Spritspartuning aus dem Shop,Schlechtwegefahrwerk, 285000 km
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post29-09-2011, 19:44    Subject: Part Number Original PD Fuel Injectors Quote
How many kilometers have you driven? If there are no problems, I wouldn't do anything. You can already check certain things with VCDS. The biggest problem is the careful installation and removal of the PD elements. The possibility of cleaning the nozzles in the ultrasonic bath still exists.
reflexsilber met.
Fabia.S
Post30-09-2011, 8:23    Subject: Part Number Original PD Fuel Injectors Quote
Currently, I have already exceeded 240,000 km, and based on the increased average fuel consumption while maintaining the same distance and speed, I suspect that new injectors would improve fuel consumption and other parameters.
"Tuning nozzles are readily available everywhere, but since I don't want to make any major performance modifications, nozzles with the same specifications would be the best choice."
I was also considering having the cleaning done, but since the components were already out, it shouldn't be due to any new nozzles.
vwSchrauber
Post30-09-2011, 12:53    Subject: Part Number Original PD Fuel Injectors Quote
Otherwise, if the components are already out, it shouldn't be due to a few new nozzles.
Don't be fooled! It seems like the PDE hasn't been decomposed yet icon_lol.gif
Post30-09-2011, 14:11    Subject: Part Number Original PD Fuel Injectors Quote
vwSchrauber wrote:
If the parts are already out, then it shouldn't be due to a few new nozzles.
Tip: Get a used PD (Personal Data Protector) and practice with it while looking at the relevant articles. icon_wink.gif
Fabia.S
Post30-09-2011, 21:52    Subject: Part Number Original PD Fuel Injectors Quote
dieselschrauber wrote:
Tip: Get a PD from a scrap yard, watch the video in the specialist articles and practice with it. icon_wink.gif
Danke, eigentlich keine schlechte Idee, da ich das letzte Mal vor genau 25 Jahren in meinem ehemaligen Beruf die Einspritzdüsen bei Motoren aufbereitet hatte, bei denen weder die Steuergeräte noch andere Sensoren oder Strom angeschlossen waren. It was all just mechanical...and it still worked at -50 degrees.
But unfortunately, I still don't have any suitable options.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post05-10-2011, 15:23    Subject: Part Number Original PD Fuel Injectors Quote
Seat Valve Set Fabia (Original) ATD Bosch 1417010989
Seat Fabia (Original) AXR Bosch 1417010984
PDE gasket set Bosch 1417010997
Passat Variant BGW 2005
Fabia.S
Post06-10-2011, 10:02    Subject: Part Number Original PD Fuel Injectors Quote
Steffen W wrote:
Seat Hole Connector Kit Fabia (Original) ATD Bosch 1417010989
PDE Bosch gasket set 1417010997
Danke, das hilft mir ja mal schon weiter und wie vermutet, sind die Seriendüsen teurer, als die meisten angebotenen Tuningdüsen.
Post06-10-2011, 19:46    Subject: Part Number Original PD Fuel Injectors Quote
...and, of course, the cheap options are not necessarily the best icon_wink.gif
No new posts Explanation of the VAG part number Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Fuel Injector Part Number: Find Yours Now! Diesel Engine Technology
No new posts Fuel Injector Nozzle Size 0.216mm - 2.5L Diesel Engine Technology
No new posts Original boost pressure sensor: kPa value. On-Board Diagnostics (OBD)
No new posts MKB ASV: STG Part Numbers & Identification Diesel Engine Technology
