Mat Guest
21-04-2004, 15:08 Subject: Water Pump Replacement: When to Change at 90,000 Miles? |
Hi everyone!!!
I got a quote from the mechanic for the 90,000 km service. They want to replace the water pump on my AFN engine 'just like that.' I can't imagine that's standard procedure, though, right?
mat
Translated on 20-09-2026, 0:38.
Sir Tortsch Guest
21-04-2004, 17:20 Subject: Water Pump Replacement: When to Change at 90,000 Miles? |
hi mat
'Why do they want to do that? As far as I know, it's not normally included.'
Julian Guest
21-04-2004, 17:23 Subject: Water Pump Replacement: When to Change at 90,000 Miles? |
Translating... |
http://www.cheesebuerger.de/smilies/schilder/10.gif
Steffarn Profi-Schrauber
21-04-2004, 20:51 Subject: Water Pump Replacement: When to Change at 90,000 Miles? |
I wouldn't participate in that either, because the water pump doesn't run directly off the timing belt  .
B.Eng (FH) u. KFZ Meister
Translated on 20-09-2026, 0:39.
Profile PM Email Garage |
Marco Guest
21-04-2004, 21:44 Subject: Water Pump Replacement: When to Change at 90,000 Miles? |
Hello everyone!!!
regards mat
Hi Mat,
For water pumps driven by the timing belt, it is common practice to replace them at the same time. The cost of a damaged or torn timing belt can be significant, and it's often not worth the risk compared to the relatively low cost of the water pump. However, it's not always necessary to replace the water pump, but a visual inspection of the water pump is the minimum that should be done.
Translated on 20-09-2026, 0:40.
PeterFaber Guest
26-04-2004, 3:58 Subject: Water Pump Replacement: When to Change at 90,000 Miles? |
We decided to proactively replace the water pump in one of our AFN TDIs after 380,000 km... visually, the old one still looked very good.
So, it wouldn't have been necessary yet...
Translated on 20-09-2026, 0:41.
Gremlin Guest
26-04-2004, 11:26 Subject: Water Pump Replacement: When to Change at 90,000 Miles? |
Depending on the vehicle's popularity, we generally perform the warranty inspection at higher mileage intervals, unless the customer strongly disagrees with this approach.
In the past, with some vehicle types, the water pump would fail around 130,000 km. Then, all the related components would have to be removed (since the water pump is driven by the timing belt in almost all vehicles), and it would cost a lot of money again.
'Those 30 euros for a wapu probably won't make a huge difference.'
There are also vehicles where the water pump never fails (including the tensioner pulley, greetings to Japan).
and there are customers who were stranded on the highway  because their WAPU (vehicle access permit) had expired, all because they wanted to save 30 euros }.
I can't say how the TDI models are, as we don't have many of them. Therefore, I don't have any experience with their acceleration.
CU Gremlin.
Translated on 20-09-2026, 0:42.
Boro Guest
26-04-2004, 12:13 Subject: Water Pump Replacement: When to Change at 90,000 Miles? |
Perhaps we could conduct a survey! I'm also considering investing the 30 euros! Engine: AFN, mileage: 196,500 km.
'However, the friendly person surprised me by immediately informing me that the replacement VAPU costs 72 euros! It must include the housing!'
But what about the AFN drivers? Are there any known cases of damage to the water pump, or has it already occurred?
Translated on 20-09-2026, 0:44.
Andy Guest
26-04-2004, 12:50 Subject: Water Pump Replacement: When to Change at 90,000 Miles? |
'With my AFN engine, I replaced the water pump at 155,000 km. The reason was a slight leak from a small metal plug in the housing. To avoid suddenly losing all the coolant while driving on the highway, I proactively replaced it.'
Andy.
Translated on 20-09-2026, 0:45.
joergs Guest
26-04-2004, 12:56 Subject: Water Pump Replacement: When to Change at 90,000 Miles? |
'On my 1Z, it failed somewhere around 170,000 - 180,000 km because it was making terrible noises!'
Mat Guest
26-04-2004, 13:33 Subject: Water Pump Replacement: When to Change at 90,000 Miles? |
Thanks for your answers so far.
Your arguments for swapping the water pump with the timing belt seem very plausible. What still makes me hesitate isn't the 62 euros for the water pump, but the cost for installation and removal on my AFN. The friendly staff charges 151.80 for that!!!!!!!!
That can't be right, can it?
best regards mat[/sup]
Translated on 20-09-2026, 0:46.
