Terminal 30 at the engine control unit (ECU) - Seat Altea
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
vwSchrauber
Post24-02-2012, 10:57    Subject: Terminal 30 at the engine control unit (ECU) - Seat Altea Quote
I have a SEAT Altea 1.9 PD in the workshop where there is no voltage reaching terminal 30 of the engine control unit (ECU). Terminal 15, on the other hand, is working correctly.
Does anyone know how this is exactly wired? Besides the battery, there's a small fuse box, and then another one located on the left side under the steering wheel, near the central electrical system.
I'm excluding the relay (109, 219, etc.) because it's connected to the constant positive terminal (terminal 30).
Greetings.
John.
Translated on 10-07-2026, 5:09.
Post24-02-2012, 11:38    Subject: Terminal 30 at the engine control unit (ECU) - Seat Altea Quote
Hello Johannes,
The engine control unit is usually mounted on a fuse box, possibly with other components attached, and located where all the other fuses are.
Don't ask me which one it is for the Altea.
Translated on 10-07-2026, 5:10.
vwSchrauber
Post27-02-2012, 12:48    Subject: Terminal 30 at the engine control unit (ECU) - Seat Altea Quote
Terminal 30 for the engine control unit (ECU) is switched via a relay in the fuse box next to the battery. That's where the fault was located.
Thank you for your help!
Translated on 10-07-2026, 5:11.
brezelmann01
Post27-02-2012, 17:02    Subject: Terminal 30 at the engine control unit (ECU) - Seat Altea Quote
Huh? Terminal 30 isn't terminal 30 when it's activated...
Translated on 10-07-2026, 5:12.
voodoo
Post27-02-2012, 19:25    Subject: Terminal 30 at the engine control unit (ECU) - Seat Altea Quote
It's been a classic for decades at Volkswagen.
The relays are developing cold solder joints, which causes the power supply to the microcontroller (MCU) to fail or the entire circuit to malfunction intermittently.
No new posts Seat Altea horn not working, cruise control Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Speed Control Retrofit Seat Ibiza / Polo Troubleshooting & Guides
No new posts AFS coding for Seat Altea On-Board Diagnostics (OBD)
No new posts GRA Light Off? Seat Altea Troubleshooting. Diesel Engine Technology
No new posts Seat Altea 5P rear wiper out of order Electrical Systems, Vehicle Electronics, Multimedia
No new posts Engine Control Units with Aftermarket Support On-Board Diagnostics (OBD)
