VW Passat 1.9 TDI - Engine Sound/Roar
Nad75
Post29-05-2017, 8:49    Subject: VW Passat 1.9 TDI - Engine Sound/Roar Quote
Good day.
My car has been making a howling noise since around October 2016. I've uploaded a video so you can hear exactly what it sounds like.
The diagnosis at the time was a turbocharger failure, so I had the turbo replaced. The only problem was that it didn't change the howling noise at all.
The Volkswagen dealership then told me that the new turbocharger was also broken and that I would have to replace it again.
I contacted the turbocharger manufacturer, and they said that the problem wasn't with the turbocharger itself, but with the car. They believe there must be a leak somewhere.
I have instructed that the following parts be replaced:
July 15: AGR valve (part number 038 131 501 AA).
Exhaust turbocharger (038 145 702 NX).
Oil supply line and oil return line.
All turbocharger boost hoses including seals.
all vacuum hoses.
Shock absorber (038 129 807).
Pressure sensor for turbocharger exhaust systems (1J0 906 627 A).
Exhaust gas recirculation pressure sensor (1J0 906 627).
I replaced these parts myself.
Solenoid valve (1J0 906 283 A)
Boost pressure sensor (038 906 051 C)
Check valve (046 905 291 A)
Unfortunately, none of this achieved the desired result. I also sent the old turbocharger in for inspection, but that didn't provide much information either, at least not for my garage. (Company correspondence and attached photos are included.)
I really don't know what else I can do. Maybe I should also mention that the car has had an *** chip tuning since 2002, which never caused any problems, and the tuning company has ruled out that it is related to the noise.
The garage maintains its opinion that the new turbo is broken, while the turbo manufacturer insists that the problem lies with the car itself.
I hope I haven't violated any rules this time, because I really need help.
Thank you in advance.
Okay, here's the translation:
Nad75
VW Passat 1.9 TDI - Engine Sound/Roar - MVI_0002.AVI
 Video heulen des Autos
 File size:  55.27 MB
 Viewed:  721 times
 Bild Turbolader
 File size:  55.35 KB
 Viewed:  1110 times
 Bild Turbolader
 File size:  45.01 KB
 Viewed:  1828 times
 Bild Turbolader
 File size:  52.62 KB
 Viewed:  1161 times
Turbolader Garrett 717858-2.pdf
 Schreiben der Firma die den alten Turbolader geprüft hat
 File name:  Turbolader Garrett 717858-2.pdf
 File size:  142.35 KB
 Downloaded:  443 times
Translated on 13-08-2026, 23:06.
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Loader won't start? Troubleshooting guide. Diesel Engine Technology
No new posts Log Passat v6 TDI Raw Upload
No new posts Passat 3BG MFL: Parts & Accessories Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat 3B: Catalytic Converter from 110 PS TDI to 115 PS ... Diesel Engine Technology
