CAN messages documented?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
anywhere
Post01-02-2012, 22:52    Subject: CAN messages documented? Quote
Hi everyone,
I am currently looking for the CAN messages used to control the xenon-AFS (Adaptive Front-lighting System) modules in the headlights of the latest generation Tiguan, for a student project (x-by-wire).
Given the temperatures, I'm not really in the mood to reverse-engineer this – meaning, I don't want to connect a CAN sniffer or oscilloscope.
I know that I can use VCDS to tell the control unit for the xenon headlights to turn them left or right. Therefore, the basic functionality would be provided...
The following questions remain open:
Can I specify an offset (e.g., "move x percent to the left"), or is only an end-stop possible?
"Does anyone know if I absolutely need the 'first' control unit? According to the wiring diagram and the SSP (Supplementary Service Publication), the control unit is connected to the regular CAN bus and has a separate CAN bus specifically for the headlights." Since I don't need any of the other functions (dependencies like steering angle, speed, etc.), the ideal scenario would be if someone could provide me with these CAN messages.
Does anyone have a list floating around? Unfortunately, the manufacturers of the control units are very secretive, and the VCDS LBL files also don't contain any useful information... :/
Sure, here's the translation:
"Thank you in advance."
Marco.
Post01-02-2012, 23:34    Subject: CAN messages documented? Quote
Hello Marco,
Unfortunately, there is no publicly available CAN database for this, so reverse engineering is required.
Try it there.
http://www.canhack.de
