VP37 Belt Installation: Guide & Tutorial
roorback
Karma: +1 / -2   Thank you, like it!
Post28-02-2012, 11:44    Subject: VP37 Belt Installation: Guide & Tutorial Quote
hello
It's a dumb question, but even with professional help yesterday, we couldn't get my TDI running again after I removed the belt from the pump. If I hadn't already successfully done it twice before, I wouldn't have attempted it.
It seemed logical to me that the process would work: setting the engine to top dead center (TDC), the pump to top dead center (marking the pump), then placing the belt, and the machine should start running.
I've successfully done it this way twice before. So why the problems yesterday? We tried many different approaches, and ultimately, the diagnosis showed no errors, and it indicated that the injection was being administered correctly.
Did I do something wrong? The installation with the markings should have worked, right?
Perhaps someone has another tip?
Today, we will use the appropriate tools to make the settings static and reset everything to the default settings. Just the 27 different markings that have accumulated on various rollers/wheels over time are enough to drive anyone crazy.
"Thank you."
"Hello"
Translated on 29-08-2026, 9:15.
roorback
Post28-02-2012, 11:56    Subject: VP37 Belt Installation: Guide & Tutorial Quote
additional question regarding the DAU:
"The pump doesn't spin at the same speed as the motor, so the timing mark should appear more frequently; is that correct? How do I find the correct UT (timing)? Or is this completely nonsense?"
Translated on 29-08-2026, 9:17.
Post28-02-2012, 13:06    Subject: VP37 Belt Installation: Guide & Tutorial Quote
It's always helpful to know what kind of vehicle you're working on. But since you're obviously an AEL fan, I'll assume that's what you're referring to.
Your pump is driven by a belt connected to the main drive shaft (NW). This means the pulley on the main drive shaft rotates at half the motor speed. This means it doesn't rotate multiple times, but essentially only half as often.
According to the diagnosis, is everything okay? Does diesel reach the injectors after loosening the locking nut?
Is everything connected correctly?
Does repeatedly replacing the belt cause the gears to shift prematurely?
Translated on 29-08-2026, 9:18.
roorback
Post28-02-2012, 13:28    Subject: VP37 Belt Installation: Guide & Tutorial Quote
Hello and thank you. Yes, VP37 with a 5-cylinder engine.
I can't even tell you if the diesel will arrive – I hadn't considered that. But could it be that there's air in the pump because of all the fiddling around?
"Hello"
Translated on 29-08-2026, 9:19.
roorback
Post28-02-2012, 15:40    Subject: VP37 Belt Installation: Guide & Tutorial Quote
"So, my colleague thoroughly analyzed the vehicle in his workshop. He said everything was misaligned, with the most extreme markings (yes, we're familiar with that). He adjusted all the basic settings, and now it's running properly again."
Then hopefully I can adjust the pump settings today and everything will be okay again.
"Thank you."
"Hello"
Translated on 29-08-2026, 9:20.
BM
Avatar-BM
Post29-02-2012, 0:33    Subject: VP37 Belt Installation: Guide & Tutorial Quote
the wildest markings (yes, yes, we know this one)-
Yeah, well, anyway, your predecessors got the ball rolling -- you didn't. icon_wink.gif
3B5 AJM
Translated on 29-08-2026, 9:21.
roorback
Post29-02-2012, 9:43    Subject: VP37 Belt Installation: Guide & Tutorial Quote
Okay, here's the latest update - things are moving forward.
I had the thing at my friend's workshop, and we took a close look at it. He thinks the "OT" (Over Torque) marking is rotated 180 degrees - could that be possible?! Is it possible to install the shock absorber upside down on this bike?!
I, for one, don't understand it, but I've accepted it and made some adjustments, and it's working better than ever.
tx
"Hello"
PS: @BMViewing profile: BM, you probably meant it as a joke, but by the way, the previous owner also had the spanner/bolt fixed, as he simply inserted it after over-tightening the thread. Another plus point for him!? icon_eek.gif
Translated on 29-08-2026, 9:22.
No new posts Timing belt replacement for Renault F9Q 1.9 dti Diesel Engine Technology
No new posts vp37 überholen Diesel Engine Technology
No new posts VP37 Compatibility: ESP vs. Other Brands Diesel Engine Technology
