Polo 6N rough idle / high CO level
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Gasoline Engine Technology
Devilseye503
Post02-05-2012, 23:57    Subject: Polo 6N rough idle / high CO level Quote
Please provide the text you would like me to translate from German to English.
Post03-05-2012, 0:46    Subject: Polo 6N rough idle / high CO level Quote
ATM --> new, used, or refurbished?
Let's start with the basics: valve timing, ignition timing.
Georg-TDI
Post03-05-2012, 8:48    Subject: Polo 6N rough idle / high CO level Quote
Since the CO level is too high, it's running too rich.
That probably isn't a vacuum leak...
As Autoservice writes,
work through the basics.
I'm experiencing the same issue with my 'Erdbeerkörbchen' (strawberry basket) when the ignition timing is too late.
No new posts Engine Misfire at High Temperature (PD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0236 - Turbocharger Overboost Condition - Bank 1 Sensor 'A' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L bis MJ 2001, Zu hoher Kilometerstand Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine mass at idle, VAG-COM value Upload
No new posts VW Polo 9N AWY - Rough idle; Adjust idle speed Gasoline Engine Technology
No new posts lupo sawing idle Gasoline Engine Technology
No new posts LMM Wert zu hoch? On-Board Diagnostics (OBD)
