bastion Blaumann
05-06-2006, 16:34 Subject: Reset Trip Meter: How to Zero Your Car's Odometer |
How can I reset a used instrument cluster (VDO 8D0 919 003N) to zero? Or am I allowed to travel abroad to a speedometer calibrator for this?
Translated on 18-10-2026, 3:36.
wolfi_b Profi-Schrauber
06-06-2006, 8:53 Subject: Reset Trip Meter: How to Zero Your Car's Odometer |
not at all -> search function! 1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 18-10-2026, 3:37.
bastion Blaumann
06-06-2006, 9:23 Subject: Reset Trip Meter: How to Zero Your Car's Odometer |
As far as I'm concerned, you can also set the mileage to the correct value, which is 30,000 km higher.
legolas09 Guest
06-06-2006, 9:41 Subject: Reset Trip Meter: How to Zero Your Car's Odometer |
Okay, so it's definitely possible to do that, and it's also not illegal, as long as it's for the purpose of repair or maintenance.
Do you have the data version available?
compare
'When creating Section 22b, paragraph 1, number 1 of the Road Traffic Act, the legislature did not intend to criminalize all forms of intervention on mileage counters, for example, for the purpose of adjustment or repair. Rather, the criminal provision aims to prevent fraudulent misrepresentation of the actual mileage of motor vehicles in the used car trade.'
Conversely, there is no manipulation if the mileage counter is accessed for the purpose of repair, adjustment, conversion, or data restoration, because these actions are aimed at ensuring or restoring the proper functioning of the mileage counter, i.e., the display of the actual mileage of the vehicle.
File number: 2 BvR 1589/05
'http://www.123recht.net/article.asp?a=16676'
Translated on 18-10-2026, 3:38.
bastion Blaumann
06-06-2006, 9:52 Subject: Reset Trip Meter: How to Zero Your Car's Odometer |
What do you mean by "data status"? Are you referring to the original mileage of the car? That's not a problem. The old instrument cluster is still installed.
Translated on 18-10-2026, 3:40.
legolas09 Guest
06-06-2006, 9:55 Subject: Reset Trip Meter: How to Zero Your Car's Odometer |
To put the AI into 'NEUMODUS' mode and reset the KM to 0, you need to have the dataset.
bastion Blaumann
06-06-2006, 10:06 Subject: Reset Trip Meter: How to Zero Your Car's Odometer |
No, I don't have that. Where can I get it? Actually, it doesn't really matter to me whether I reset the mileage to zero or adjust it to the correct value. I would actually prefer to adjust it to the correct value.
Translated on 18-10-2026, 3:41.
legolas09 Guest
06-06-2006, 10:26 Subject: Reset Trip Meter: How to Zero Your Car's Odometer |
Okay, you need to read out the data status.
Okay, now tell me why you need all of this to even begin to estimate what you actually need!
bastion Blaumann
06-06-2006, 10:35 Subject: Reset Trip Meter: How to Zero Your Car's Odometer |
Okay, I'm planning to retrofit my B5 (year 1996) with a FIS (multifunction display) and additional gauges. That's why I bought a suitable instrument cluster from a salvage yard. However, of course, the mileage displayed on the new instrument cluster doesn't match (it's about 30,000 km too low).
Darum will ich den Kilometerstand vom alten KI auf das neue übernehmen. Bei meinem alten KI konnte ich den Kilometerstand mit VAGCom ändern. Darum hatte ich auch hoffnung das es bei dem anderen auch klappen könnte. Gedoesn't.
It doesn't matter to me whether I send the car in for repairs now and receive it back with a reset odometer, and then enter the mileage myself, or whether the correct mileage is set directly. I just want the car to display the correct mileage, mainly for warranty and insurance purposes.
I don't have any hardware at home to read the data or directly program the EEPROM. That's why I'm looking for someone who can do it for me.
Translated on 18-10-2026, 3:42.
legolas09 Guest
06-06-2006, 11:42 Subject: Reset Trip Meter: How to Zero Your Car's Odometer |
Okay, so if that's the case, I'm sure I can help you --> PM (private message).
Translated on 18-10-2026, 3:43.
Nebelwerfer_TDI Guest
06-06-2006, 11:47 Subject: Reset Trip Meter: How to Zero Your Car's Odometer |
With my old AI (Artificial Intelligence) system, I could change the mileage using VAGCom.
 Tell us how you did it?! Did you decompile VAG COM and search for the relevant section (perhaps an 'if' statement?!) in the program code, and then modify it?
Translated on 18-10-2026, 3:44.
bastion Blaumann
06-06-2006, 11:52 Subject: Reset Trip Meter: How to Zero Your Car's Odometer |
No, just log in with "13681", select channel 9, and enter the new value.
This was just a test, with a range of -10km and then +10km. Perhaps the small difference was the issue, or maybe some NSI tachographs were shipped with debugging software.
Translated on 18-10-2026, 3:45.
06-06-2006, 12:02 Subject: Reset Trip Meter: How to Zero Your Car's Odometer |
No, just log in with '13681', select channel 9, and enter the new value.
I should probably try that sometime.
For some KIs, VAG COM even provides direct assistance by displaying information when you hover the mouse cursor over the relevant adaptation channel. In the case of the channel responsible for the odometer reading, I once read on a G4 KI that it only works for values below 100 km (as described somewhere else).
legolas09 Guest
06-06-2006, 12:54 Subject: Reset Trip Meter: How to Zero Your Car's Odometer |
With some KIs, VAG COM even provides direct assistance by displaying information when you hover the mouse cursor over the relevant adaptation channel. In the case of the channel responsible for the odometer reading, I once read on a G4 KI that it only works (as described somewhere here) for values below 100 km.
I only know it like that  .
Translated on 18-10-2026, 3:47.
06-06-2006, 16:59 Subject: Reset Trip Meter: How to Zero Your Car's Odometer |
Quote: |
However, the mileage displayed on the new AI system is incorrect (it's approximately 30,000 km too low).
Why not simply connect a rectangular wave generator to the input of the speedometer and then apply the appropriate frequency (by trial and error)? 30,000 km is 120 hours (or 5 days) at 250 km/h. However, the question is what the car's computer needs in order to run far enough to increment the mileage.
Jan. 1Z5 CFHF  / AHB H4D
Translated on 18-10-2026, 3:48.
bastion Blaumann
07-06-2006, 6:39 Subject: Reset Trip Meter: How to Zero Your Car's Odometer |
If I knew where I needed to connect this, it wouldn't be a problem.
Translated on 18-10-2026, 3:49.
