I'm just guessing here, since I don't know for sure: You'll probably need a BNSTG (Battery, Neutral, Start, Transmission, Ground) signal to tell the radio, via the GW (Gateway) and subsequently the other CAN bus, that the ignition is on. The ignition switch can certainly be simulated with a regular switch.
