BMP consumes too much resources.
Baba
Registered VCDS User
Post05-05-2012, 19:51    Subject: BMP consumes too much resources. Quote
Despite various other "issues," I'm still bothered by what I perceive as excessive fuel consumption of my Passat (BMP with DSG).
Can we possibly interpret something from this log? I suspect it's running too rich, but if so - why? Is it possible that the lambda sensor reports excessively high values?
In the steady-state operation, Lambda can even reach 25 or so - is that normal?
I'm looking forward to any tips.
Greetings
Roland
LOG-01-001-067-074.CSV
 Beschleunigung nach Autobahnauffahrt, teilw. Vollgas, Motorkennbuchstabe BMP
 File name:  LOG-01-001-067-074.CSV
 File size:  22.45 KB
 Downloaded:  592 times
Post05-05-2012, 22:08    Subject: BMP consumes too much resources. Quote
Lambda at 1.3 under full load is ok, as are the high values at low load:
/viewtopic.php?t=26448
However, the backpressure in your DPF seems a bit high, and it would be useful to compare it with other engines. Ash mass?
Best regards, Rainer
Post06-05-2012, 9:11    Subject: BMP consumes too much resources. Quote
In April, Baba wrote
My DPF is now showing 61g of ash
If he didn't do anything, then the thing is fine.
It's my fault, because who would do something like this:
Diesel Particulate Filter (DPF) mileage approximately 155,000 km, engine mileage approximately 50,000 km (estimated)
If I remove the engine at 105,000 km, will I ALWAYS have to replace the DPF!
Baba
Post06-05-2012, 11:32    Subject: BMP consumes too much resources. Quote
Hello again,
Of course, I had also envisioned this - but it is clearly not a requirement at VW. The engine replacement (including the turbo) was ultimately carried out under warranty.
If he didn't do anything, then the thing is fixed
He has done something, providing a great guide icon_wink.gif - but the success...
It would be great to have an actual comparative value for the differential pressure. At least, before the "DPF cleaning", the value at idle was much higher, and at full load, it was also somewhat higher, exceeding 350 mbar...
What about consumption? What if the lambda sensor sends incorrect values to the control unit, could this potentially result in a rich mixture, and could this explain the smell of the exhaust gases (not always, but often also shortly after engine start)?
Are the high temperatures before and inside the DPF still within the normal range during normal driving?
Post07-05-2012, 7:40    Subject: BMP consumes too much resources. Quote
Mixture to fat,
Mix ?? You have a diesel!
If too much is injected, it will stall.
If you had contacted me 2 weeks ago, I would have had a BMP available for testing.
Post07-05-2012, 10:01    Subject: BMP consumes too much resources. Quote
In the operating mode, your lambda value is simply not defined, as there is no fuel and no calculated air-fuel ratio.
Before you start searching for pseudo-scientific solutions based on half-truths: Read a book, learn how diesel engines work.
In itself, this diesel mechanic has said everything there is to say about the book, which makes reading it much shorter.
Baba
Post07-05-2012, 16:03    Subject: BMP consumes too much resources. Quote
@matthiasTDI96Viewing profile: matthiasTDI96 - Sorry, the term "mixture" was probably a bit misleading icon_redface.gif
I would be interested in seeing some comparative values, and whether it is even possible that the cause of increased fuel consumption (+ soot production) could be a faulty lambda sensor.
I just thought that this forum provides useful support to someone who isn't an expert, especially when dealing with "half-knowledge" or even less.
Post07-05-2012, 21:20    Subject: BMP consumes too much resources. Quote
As far as I know, the ECU doesn't really care what the lambda sensor is saying - at least as long as it's not completely out of control.
Here (Diesel) nothing is lambda-regulated.
Post07-05-2012, 21:33    Subject: BMP consumes too much resources. Quote
It also doesn't mean that no one is offering support. However, the responses that are given must also be read. The mixture and air-fuel ratio are primarily irrelevant to the diesel engine.
No new posts Loud TDi engine (81 kW) and excessive fuel consumption Diesel Engine Technology
No new posts Too much oil: Causes and solutions Diesel Engine Technology
No new posts Best German Shepherd Breeders: Find Yours Now! Diesel Engine Technology
No new posts TDI PD Engine: Power or Just Noise? Diesel Engine Technology
