Audi C4 Engine Control Label File: V6 (12V) AAH
DirkC4
Post06-08-2012, 20:46    Subject: Audi C4 Engine Control Label File: V6 (12V) AAH Quote
Is there a label file available for the engine control unit (ECU) for an Audi C4 (4A) V6 (12V) AAH, manufactured in MJ.93?
In the corresponding redirect file "4A-01.lbl", the line:
Code:
;REDIRECT,4A0-906-266-AAH.LBL,4A0-906-266-???  ; AAH
is found, but it is commented out.
and a file named "4A0-906-266-AAH.LBL" cannot be found on the computer either.
It's about obtaining the most complete sets of measurement data possible, displaying them in the correct units, etc.
(I am using VCDS RKS version 11.11.3)
Please provide the German text you would like me to translate into English.
Translated on 16-10-2026, 3:21.
vagtuning
Post07-08-2012, 13:25    Subject: Audi C4 Engine Control Label File: V6 (12V) AAH Quote
You could create copies and submit them.
http://wiki.ross-tech.com/wiki/index.php/Control_Module_Maps
Translated on 16-10-2026, 3:22.
DirkC4
Post07-08-2012, 15:40    Subject: Audi C4 Engine Control Label File: V6 (12V) AAH Quote
Thank you for the link.
Sure, I understand. Please provide the German text you would like me to translate into English. I will do my best to provide an accurate translation.
Don't be upset.
but I thought that for a vehicle that's 20 years old,
and such a widely used machine.
Someone must have done that before.
Over the nearly equally long development history of VAG-Com/VCDS...
"For that price, the system is simply too expensive, especially considering that it lacks such basic features."
Translated on 16-10-2026, 3:23.
Post07-08-2012, 16:04    Subject: Audi C4 Engine Control Label File: V6 (12V) AAH Quote
Hello Dirk,
Go to "Applications" in the main VCDS screen, and then select "Control Unit Map".
Enter the control unit address (e.g., 01 for the engine control unit) and select whether you want to scan measurement blocks or adjustment channels.
The created .pla or .plb files can then be found in the "Logs" subdirectory of the VCDS installation directory.
Please send the files to me or directly to Ross-Tech.
Translated on 16-10-2026, 3:24.
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts Audi A2 to A6, Engine Area, Generosity Policy Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Audi A4, Engine not starting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problems with label file in 607.3 On-Board Diagnostics (OBD)
No new posts BLS Label File: Guide & Download On-Board Diagnostics (OBD)
No new posts STG09 Label File for Golf GTI 2009 On-Board Diagnostics (OBD)
No new posts 1Z Motor Audi 80 B4: Make the engine more fuel-efficient Diesel Engine Technology
