Oil Separator: What is that black box on the cylinder head?
Wolfgang, syncro16
Post16-04-2003, 18:03    Subject: Oil Separator: What is that black box on the cylinder head? Quote
I once looked at the round black box on the cylinder head of my car. I previously thought it was an oil separator or a pressure valve. However, as far as I could tell without damaging it, it only contains a thin membrane and a thin spring. When I blew air through it, the air flowed through all the openings. The connections to the cylinder head and the crankcase are directly connected by the mostly empty housing. The connection to the turbo comes from the center and could potentially be blocked by the membrane and spring, but as I said, it is also open.
My guess is that it's a check valve that prevents oil from being sucked in when the air filter is clogged.
Does anyone have a better suggestion?
'I'm concerned that oil is apparently entering the intake manifold through the crankcase ventilation system, and over time, this is filling up the intercooler, which reduces its effectiveness. I would therefore like to install an oil separator. Where can I find a suitable one? The one from the V8 TDI is probably too large.'
Do newer 4-cylinder TDI engines have anything special?
'I'm familiar with this white canister located between the crankcase and the cylinder head; it doesn't seem to do much. Is this an empty canister, or does it contain some kind of technology?'
Hello.
Wolfgang.
Translated on 22-10-2026, 5:54.
Maciek
Post17-04-2003, 12:13    Subject: Oil Separator: What is the Black Box on the Engine? Quote
Hi Wolfgang,
According to the catalog, this is a pressure regulating valve. I'm not exactly sure what it does. There's a separate oil separator (which I don't have on my engine).
Is that the white can you're talking about?
1c ETnr: 052 103 495
The turbo will also inject a small amount of oil into the coolant.
Apparently, the Polo TDI also has an oil separator, but I can't find it. Maybe someone in the 165 forum knows where it is.
Maciek.
Translated on 22-10-2026, 5:57.
haehnlein
Post17-04-2003, 17:17    Subject: Oil Separator: What is the Black Box on the Engine? Quote
Wolfgang, syncro16 wrote:
I'm concerned that oil is apparently entering the intake manifold through the crankcase ventilation system, and over time, this is filling up the intercooler, which reduces its function.
remember that the oil mist has an important function: lubricating the intake valves icon_exclaim.gif.
____________
Kein Auto mehr!
Translated on 22-10-2026, 5:58.
No new posts Document Transporter 7D, vacuum pump making noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K: Drum Brake Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Air conditioning compressor making noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil separator for VW Golf IV Diesel Engine Technology
No new posts Vintage Tin Can Diesel Engine Technology
No new posts Vacuum in VTG Can: Troubleshooting & Solutions Diesel Engine Technology
No new posts VTG Valve Diagnosis: CBAB Unit Repair On-Board Diagnostics (OBD)
