Hello T3 enthusiasts!
You could try looking for a voltage regulator (if there is one) on the circuit board, find it, and replace it as a precaution. That would be the most cost-effective solution.
Otherwise, it looks like there's a processor error, as the LCD is also no longer being controlled correctly. Replacing it is difficult, but possible with the right equipment (an SMD hot air rework station).
See: [url][/url]
Best regards from Munich!http://www.codecard.lt/electronics/2j74y/mc68hc908az60-2j74y-processor-already-programmed-with-software-you-need/prod_127.html{MARKER}
