diesel.gustav wrote: |
1.) The C1000 represents the velocity profile of the distributor piston at 1000 pump revolutions. It is a frequently used reference value in pump applications. |
Hello Gustav.
Ah, yes, now it's clear. I couldn't interpret the "1000".
Quote: |
| 3.) Regarding your comment: "changing the injectors is closer to engine tuning" than the commonly used method of extending the injection time." This was not about "tuning" but about further development. The larger injector nozzles were only a small part of it. The entire injection system, the EDC, the turbocharging, and even the engine itself were modified. |
Yes, of course. But at the moment,
I was only concerned with the aspect of increasing the injection quantity, which is often already the whole (subsequent) tuning process.
Quote: |
| 4.) Regarding the full-load injection duration, the two images have little in common. They definitely represent two different operating states, because C1000 means 2000 RPM on the engine, and if, as in the other image, it refers to power, it means the rated power speed of 4150 RPM. |
Ah, it's starting to make sense.
At 2000 rpm , the full-load injection duration in °KW will be approximately double the pump delivery duration in °NW, so about 24° KW.
The increase in injection angle at Pmax = 4150 rpm to 36° KW is mainly due to the pump characteristic curve (extension of the injection angle duration at high speeds due to "too small" nozzle bore diameters, etc.) - and the small change in the effective full-load quantity between 2000 and 4150 rpm is considered negligible.
Thank you for your insightful answers
