Fabia 2: LWR Headlight Wiring Explained
Headnut
2012 Skoda Octavia
Post15-12-2012, 14:07    Subject: Fabia 2: LWR Headlight Wiring Explained Quote
Hello community,
I'm having a problem with my wife's Fabia.
after troubleshooting a different issue (which has now been resolved).
Will I be able to handle this problem myself, or do I need to go to the icon_biggrin.gif?
The fuses have all been checked, so it shouldn't be a problem with them.
Thank you for your help.
Hi Headnut.
Log-TMBBH65J8A3103897-37430km-fabia3.txt
 Der letzte Scan mit dem Fehler in der Leuchtweitenregulierung.
 File name:  Log-TMBBH65J8A3103897-37430km-fabia3.txt
 File size:  5.84 KB
 Downloaded:  2082 times
Log-TMBBH65J8A3103897-37430km-Fabia .txt
 Der 1.Scan vom Ursprünglichen Problem
 File name:  Log-TMBBH65J8A3103897-37430km-Fabia .txt
 File size:  4.96 KB
 Downloaded:  1853 times
Translated on 12-09-2026, 20:38.
Post15-12-2012, 14:26    Subject: Fabia 2: LWR Headlight Wiring Explained Quote
Please provide a more detailed explanation icon_wink.gif.
- Error description
- previous errors
- What repair attempts were made?
Unfortunately, that won't work.
Translated on 12-09-2026, 20:39.
Headnut
2012 Skoda Octavia
Post15-12-2012, 14:59    Subject: Fabia 2: LWR Headlight Wiring Explained Quote
Okay, here's the entire story.
The battery was dead, and my father-in-law came to jump-start the car.
Unfortunately, he had reversed the polarity, and as a result, he initially...
The wires were short-circuited, which naturally also blew a few fuses.
A fuse was located directly on the battery, which is why the servo unit failed. Additionally, the fuse inside the radio (an aftermarket radio) was also defective. Unfortunately, I had checked all the fuses inside the car before I found the defective fuse near the battery, as I had already confirmed that all the relevant fuses inside were fine.
Since I've checked everything, the problem with the LWR (likely referring to a specific system or component) is the cause, and it's not related to incorrect polarity.
Okay, so if I clear the error code using VCDS, the automatic headlight range adjustment starts going up and down, and then the error code reappears. I just drove the Fabia around a bit, and after a while, the warning light in the instrument cluster goes out. After restarting the car, it happens again, and then it disappears after a few minutes.
Translated on 12-09-2026, 20:41.
Post15-12-2012, 16:18    Subject: Fabia 2: LWR Headlight Wiring Explained Quote
Since I have checked them all, the problem with the LWR is still present, so it is not related to the polarity.
Apparently not. Reversing polarity is always very bad, or unpredictable, as to what will happen. Anything is possible.
"First, I would disconnect the battery for a few minutes and then re-check the fuses. It's possible that something overheated, there's a contact issue, or a fuse is blown."
Translated on 12-09-2026, 20:43.
Post15-12-2012, 17:27    Subject: Fabia 2: LWR Headlight Wiring Explained Quote
And do not upload any images from repair manuals for which you do not have the rights. icon_rolleyes.gif
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post15-12-2012, 17:39    Subject: Fabia 2: LWR Headlight Wiring Explained Quote
http://wiki.ross-tech.com/wiki/index.php/02233
Is everything working?
If so, stay calm, and after a few days, read the error memory.
reflexsilber met.
Translated on 12-09-2026, 20:44.
Headnut
2012 Skoda Octavia
Post16-12-2012, 12:32    Subject: Fabia 2: LWR Headlight Wiring Explained Quote
@dieselschrauberViewing profile: dieselschrauber
Okay, it wasn't my intention.
@RedR32Viewing profile: RedR32
Okay, as far as that goes, I don't really have any other choice.
No new posts Polo 9N / Ibiza 6L / Fabia 2: Generator does not charge Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts EDS in Skoda Fabia RS On-Board Diagnostics (OBD)
No new posts Fabia RS ASZ: Parts for 2001-2011 Models Upload
No new posts DK Skoda Fabia 1.4L 16V Gasoline Engine Technology
No new posts Differential Pressure Sensor Skoda Fabia 5J On-Board Diagnostics (OBD)
