Gear ratio for 1Z and AFN engines
Diesel-Dirk
Post15-04-2002, 15:55    Subject: Gear ratio for 1Z and AFN engines Quote
Does anyone know of any Gertie translations for the 1Z and AFN engines?
Or where can I find something like that?
Thank you!
Avatar-Jan6K
Post15-04-2002, 16:56    Subject: Which car? Quote
It depends on the car! For example, for the Golf Mk3, the gear ratios of the AFN engine are identical to those of the Ibiza 6K with the ASV engine, and this information can be found in the technical specifications on seat.de. Alternatively, I can provide you with those gear ratios if they are the ones you are looking for...
Stukov
Post15-04-2002, 19:09    Subject: Gear ratio for 1Z and AFN engines Quote
The 1Z has 2 types of transmissions: ASD or CTN.
The AFN has 1 gearbox: CYP.
Each day, from 1st to 5th. Forward gear, axle ratio, and reverse gear.
ASD: CTN: CYP:
3,300 3,778 3,778
1,944 2,118 2,063
1,308 1,360 1,348
0.917 0.971 0.967
0.717 0.756 0.744
3,600 3,600 3,600
3.158 3.158 3.158
Everything from the Golf Mk3.
C.F.
Post17-04-2002, 15:26    Subject: Gear ratio for 1Z and AFN engines Quote
Do these specifications also apply to my Passat 35i, model year 1995, with a 1Z engine, or are the Golf and Passat different in this regard?
Stukov
Post17-04-2002, 15:38    Subject: Gear ratio for 1Z and AFN engines Quote
Good question. You could look for the gearbox identification letter, and that would definitely help. It's less likely if someone else's name is on it.
No new posts Gear Ratio Calculation CEP Needed Diesel Engine Technology
No new posts Gear Ratio Passat DQS Diesel Engine Technology
No new posts Gear Ratio Calculation / Maximum Load Capacity Diesel Engine Technology
No new posts Gear Ratio & Axle Ratio Audi A3 TDI 81kw Diesel Engine Technology
