dave81
Joined: 11/10/2012 Posts: 13 Karma: +0 / -0 Location: Oberhausen 2005 Audi A3 Premium Support
07-02-2013, 14:49 Subject: Do you need to register the battery after replacing it in an Audi A5? |
Unfortunately, we were unable to find any information on this topic specifically related to the A5. For the A6, the new battery is programmed in control unit 61. Is that the case with the A5 as well?
The new battery should be coded using VCDS.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
07-02-2013, 15:45 Subject: Do you need to register the battery after replacing it in an Audi A5? |
Quite likely, yes. A car scan is always helpful.
Profile PM WWW Garage |
dave81
07-02-2013, 23:41 Subject: Do you need to register the battery after replacing it in an Audi A5? |
Hi, thanks for the information. Unfortunately, I don't have a scan yet.
Profile PM Garage |
