Error code in A3 8PA gasoline engine
Post02-11-2014, 19:39    Subject: Error code in A3 8PA gasoline engine Quote
Hi.
My knowledge of spark plugs is a bit patchy.
"What does the STG mean by that?"
Code:
                Adresse 01: Motorelektronik       Labeldatei: RKS\03C-906-056-BAG.lbl
   Steuergerät-Teilenummer: 03C 906 056 CP    HW: Hardware No
  Bauteil und/oder Version: MED9.5.10        00 7956
                 Codierung: 0000072
            Betriebsnummer: WSC 06314 000 00000
                      VCID: 73EE4F8E12CE5886965-8026
2 Fehlercodes gefunden:
012408 - Drosselklappensteuereinheit
               P3078 - 002 - Luftdurchsatz im Leerlauf zu gering - Sporadisch
             Freeze Frame:
                    Fehlerstatus: 00100010
                    Fehlerpriorität: 0
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 255
                    Kilometerstand: 168244 km
                    Zeitangabe: 0
                    Datum: 2014.10.29
                    Zeit: 16:03:09
             Freeze Frame:
                    Drehzahl: 880 /min
                    Last: 27.0 %
                    Geschwindigkeit: 22.0 km/h
                    Temperatur: 23.0°C
005000 - Steuergerät defekt - E-Gas Überwachung
               P1388 - 008 -  - Sporadisch
             Freeze Frame:
                    Fehlerstatus: 00101000
                    Fehlerpriorität: 0
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 255
                    Kilometerstand: 168289 km
                    Zeitangabe: 0
                    Datum: 2014.11.01
                    Zeit: 12:25:48
             Freeze Frame:
                    Drehzahl: 1640 /min
                    Last: 11.0 %
                    Geschwindigkeit: 33.0 km/h
                    Temperatur: 81.0°C
Readiness: 0000 0001
Translated on 11-07-2026, 23:45.
Jan6K
Avatar-Jan6K
Post02-11-2014, 19:45    Subject: Error code in A3 8PA gasoline engine Quote
What does the throttle valve look like? A heavy buildup of dirt could explain this. Our BBY experienced similar issues and was throwing error codes due to an extremely dirty throttle valve.
Jan.
1Z5 CFHF / AHB H4D
Translated on 11-07-2026, 23:46.
Post02-11-2014, 19:54    Subject: Error code in A3 8PA gasoline engine Quote
YES.
We recently had the AGR replaced (due to tooth loss and subsequent permanent occlusion).
With that old engine, you need to remove the cover with the integrated air filter, and then you can see the throttle valve directly.
The DK didn't look as good as the ones I cleaned at the T3 recently.
Do you think the following will help (besides the fact that I got to do some tinkering)?
expand
- clean
- refresh with new poetry.
What do these throttle body cleaners do?
Translated on 11-07-2026, 23:47.
Jan6K
Avatar-Jan6K
Post02-11-2014, 20:27    Subject: Error code in A3 8PA gasoline engine Quote
and you can see the throttle valve directly.
It's the same with the BBY. If you open it now with your finger and look at the underside, you can see – at least with the BBY – the real disaster. Because directly underneath, the AGR (Abgasrückführung) valve is located. I manually removed about 2 mm of dirt (using a wooden spatula, so as not to scratch anything), and then cleaned the rest with brake cleaner.
Disassembling, cleaning, and reinstalling with new seals is exactly what helped with the BBY issue. After that, it just needed to be recalibrated, and everything was fine.
Jan.
1Z5 CFHF / AHB H4D
Translated on 11-07-2026, 23:49.
Post02-11-2014, 23:08    Subject: Error code in A3 8PA gasoline engine Quote
Okay.
Okay, then I know what to do.
It wasn't exactly 2mm when I pried open the cover out of curiosity, but since the EGR valve ends up in the same position as you described, it was more than that sticking out above it.
Translated on 11-07-2026, 23:51.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Initial Setup with VCDS (Gasoline Engine) Troubleshooting & Guides
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Fuel consumption for gasoline engines? Diesel Engine Technology
No new posts BFQ 1.6 Petrol Engine Gasoline Engine Technology
No new posts Hydroclack 3.7 Gasoline Engine Noise Gasoline Engine Technology
No new posts Turbocharger: Can a Gas Engine Fit a TDI? Diesel Engine Technology
