Design question: Lubrication of PDEs
Post23-01-2005, 13:30    Subject: Design question: Lubrication of PDEs Quote
It is probably now widely known that PD engines require a highly specialized type of oil.
The reason given is the high surface pressure in the plasma drive.
Attached is my interpretation of the problem, where the tilting arrow above the adjustment screw is intended to represent the movement of the tilting lever.
During the injection phase, the adjustment screw and ball joint exert estimated forces in the tens of kilograms range, which would essentially "squeeze" the oil (along with the tilting motion) out of the contact surface between the adjustment screw and the ball joint – something that probably happens with normal oil as well, if I understand the situation correctly.
Only PD oil remains smearable there, despite the incredibly high pressures in the storage.
But how does it actually get there, between the adjustment screw and the ball stud?
Do the rocker arm shaft, rocker arm, and adjustment screw have oil holes and channels that allow oil to reach the critical areas?
Or is the oil transported by injection within the valve cover, and does the oil itself draw into the flat surface between the adjustment screw and the ball stud due to the tilting motion?
If so, from where does the oil spray towards the PDE lubrication points?
 File size:  28.05 KB
 Viewed:  1737 times
Tengola
Post16-08-2013, 17:24    Subject: Lever oil channel Quote
Hi Ulf.
Lubrication is provided by the pivot lever shaft, or... Lever handles, as long as the lids are tightly closed.
Karma: +1344 / -0   Thank you, like it!
Post17-08-2013, 10:17    Subject: Design question: Lubrication of PDEs Quote
It seems there's a misunderstanding. The adjustment screw on PD motors is solid. The lubrication between the adjustment screw and the ball stud is done with a special grease.
What is shown in the thread is the "drag link carrier" with an axial bore and a sealing plug.
No new posts Oil proliferation in the ASZ. Incorporate PDEs and images Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbo Lubrication: Observations and Analysis Diesel Engine Technology
No new posts [Poll] PDEs for ATD or AXR Diesel Engine Technology
No new posts Durable PDEs: Longevity and Reliability Diesel Engine Technology
No new posts Problem with PDEs? Upload
