Golf 6 1.4 TSI CAXA - Power issues, cold start problems
anywhere
Post28-10-2013, 2:31    Subject: Golf 6 1.4 TSI CAXA - Power issues, cold start problems Quote
Hi everyone,My sister's Golf is a real "Monday car," meaning it's been causing problems frequently. It now has about 18,000 miles on the odometer, and several repairs have already been done, including: Transmission (noise, oil full of debris) and turbocharger (wastegate issue).Okay, so I put the winter tires on yesterday, and during the test drive, I noticed that the car pulls extremely poorly when it's cold. The second gear feels like the turbo is completely missing. Starting at around 2200-2500 rpm, it starts up as usual.It's not the stuck wastegate with the "wave motion," but it feels like some software is preventing the full power from being released?!Okay, I got a notebook and took it for a test drive (attached are the results), and so far, everything seems normal to me.The interesting thing is: once the engine is warm, it drives exactly as you would expect. Neither the log files nor the pop meter showed anything unusual.Unfortunately, it's difficult to find information about this problem online, because it seems like the wastegate is failing in almost every other Golf, and I don't want to read through 100 pages of MT forum posts...Has anyone ever heard of a similar problem before?If desired, I would be happy to perform another cold start log, so please provide the relevant MWB values. 3-8-11 is probably boring icon_wink.gif. Thank you very much for your tips!Marco.
VCDS Auto-Scan Printout katja.pdf
 Umgebungsbedingungen
 File name:  VCDS Auto-Scan Printout katja.pdf
 File size:  23.87 KB
 Downloaded:  1468 times
LOG-01-115-118-141.CSV
 2. Gang
2. Gang
 File name:  LOG-01-115-118-141.CSV
 File size:  5.61 KB
 Downloaded:  1008 times
LOG-01-115-118-141_2gang.CSV
 Beschleunigung ab dem 2ten Gang
 File name:  LOG-01-115-118-141_2gang.CSV
 File size:  5.97 KB
 Downloaded:  1001 times
Post29-10-2013, 18:32    Subject: Golf 6 1.4 TSI CAXA - Power issues, cold start problems Quote
Hello,The differences in air mass flow between "normal" and "conservative" driving modes at full throttle within the specified RPM range would be interesting, as would the values of the lambda control system.Also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also, also,I don't know the MWBs off the top of my head.Best regards, Rainer.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 3 TDI AFN: Troubleshooting Performance Issues Diesel Engine Technology
No new posts Golf 3 TDI 81kW power issues Diesel Engine Technology
This topic is locked, you cannot edit or reply. 1Z Engine Problems: Loss of Power, Cold Start, Data On-Board Diagnostics (OBD)
No new posts CAXA: Boost pressure error, turbocharger replacement, new... Gasoline Engine Technology
