F B Guest
06-12-2013, 13:12 Subject: Which version do I need? |
I am a little confused about the prices and versions.
I basically want to get rid of everything old and I have no idea which VCDS version is absolutely necessary.
Are there any lists available that show which version corresponds to which price and what features it offers?
Best regards, Frank
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
06-12-2013, 13:21 Subject: Which version do I need? |
HEX-USB+CAN VCDS/OBD2 Professional Diagnostic System KKL+CAN (USB), for all vehicle models, it supports K-Line and CAN-Bus.
Suitable for both old and new vehicles, thus future-proof.
F B Guest
06-12-2013, 13:34 Subject: Which version do I need? |
Um, yes, thank you first.
Where and at what price can it be ordered?
What are the prerequisites?
Is USB 1 therefore obsolete?
Is it sufficient if I drill the laptop's port via a PCMCIA card to USB 2.0?
(Power supply, transmission speed, etc.)
How much storage does the laptop need?
Surprisingly, this old piece of hardware is still running smoothly with 256 MB of RAM under XP and is handling all my needs so far.
Browsing the internet, searching for parts and instructions, even a free OBD2 software is available.
Is VCDS a memory hog?
Best regards, Frank
06-12-2013, 14:19 Subject: Which version do I need? |
Check this out: http://shop.dieselschrauber.de/
Usb1 should work.
Blackfrosch Schrauber
06-12-2013, 14:29 Subject: Which version do I need? |
VCDS also runs flawlessly even on very old and outdated hardware, because the communication is handled by the interface.
06-12-2013, 14:42 Subject: Which version do I need? |
USB 1 is definitely working. It even works when you plug the USB into a virtual machine. The VM itself doesn't generate any significant load... therefore, it's completely unimportant.
Jan
1Z5 CFHF  / AHB H4D
06-12-2013, 18:35 Subject: Which version do I need? |
Quote: | | It can even work if you plug the USB drive into a virtual machine |
But we really don't want to cultivate that -- we just had an issue with it not working properly with an apple. The hardware should be suitable for computer novices.
This does not mean that VCDS would not run on a VM...
Herbert Profi-Schrauber
06-12-2013, 19:12 Subject: Which version do I need? |
To give you an idea, I'm using VCDS in the HEX-USB+CAN version with 2x2 adapters. In the garage, it runs on a Compaq Armada 1750 with USB1 (basically from the previous century), with WIN XP SP2, 128 MB RAM. "This allows for the connection of the vehicle with a 2x2 adapter, and also for communication with a VW model from 2012 via OBD2 I/F."
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
06-12-2013, 20:27 Subject: Which version do I need? |
Profile PM WWW Garage |
