brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
19-01-2014, 9:14 Subject: Oil Change Reset Log: Unclear Instructions |
Hello!
I changed the oil in my A3 and saved the LOG data before and after resetting the service interval indicator. The descriptions don't quite make sense to me. Is this a bug, or am I mistaken?
The result of the reset, on the other hand, has always been satisfactory so far.
What I find illogical is the description of "Kanal"...
40, 41, 42, 43, 44: One inspection, one service. And suddenly, an oil change on channel 50?! In my opinion, everything should be labeled as "oil change."
Especially since, according to the current definition, channels 40 and 53 would be showing the same content...
Dirk.
| Description: |
 Download |
| File name: |
Log-DEL-BD22-WAUZZZ8P9BA0XXXX-65919-nach ölwechsel.txt |
| File size: |
2.3 KB |
| Downloaded: |
1412 times |
| Description: |
 Download |
| File name: |
Log-DEL-BD22-WAUZZZ8P9BA0XXXXX-65919-vor ölwechsel.txt |
| File size: |
2.58 KB |
| Downloaded: |
760 times |
Translated on 03-08-2026, 10:19.
bloesch Profi-Schrauber
Joined: 03/18/2005 Posts: 622 Karma: +16 / -0 Location: FL
19-01-2014, 10:52 Subject: Oil Change Reset Log: Unclear Instructions |
Quote: | What I find illogical is the description of the channel...
Current Audi models distinguish between three types of service appointments:
- Time-dependent tasks (e.g., inspections, mandatory technical safety checks, vehicle registration tests).
- Maintenance items based on mileage (e.g., inspection, timing belt, air filter...).
and
- Oil change (calculated based on usage).
Each of these events can cause the service indicator light to illuminate.
Translated on 03-08-2026, 10:21.
19-01-2014, 12:21 Subject: Oil Change Reset Log: Unclear Instructions |
Yes, I understand that. But I only reset a flexible oil change service. And with that, shouldn't only the channels related to the oil be reset? And wouldn't the description for those channels then actually be the same?
Translated on 03-08-2026, 10:22.
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
19-01-2014, 14:24 Subject: Oil Change Reset Log: Unclear Instructions |
40 and 41 refer to the last reset operation.
The rest has remained intact.
