haithamina Schrauber
Joined: 05/15/2006 Posts: 666 Karma: +27 / -3 Location: 69221 Dossenheim
04-02-2014, 14:00 Subject: Fuel Injectors AVB - Buy Now! |
The car has now covered a little over 230,000 km, and it doesn't consume noticeably more fuel than when it was new with 45,000 km. It only produces a little smoke when driven at full throttle. So, it seems everything is okay.
Since I'm considering whether to keep the car or sell it, I'd like to know how much fuel injectors (or injector components?) cost, and what other work/expenses I might incur if I want to replace worn-out parts.
Can anyone here give a rough estimate?
Are there any competent providers in the HD region?
It seems like that topic is no longer available in the shop?
You're welcome! haithamina
Translated on 08-09-2026, 0:17.
Joined: 04/12/2002 Posts: 18131 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
04-02-2014, 14:12 Subject: Fuel Injectors AVB - Buy Now! |
Quote: | | Can anyone here roughly estimate that? |
Yes. The problem is that you can't do it. Unfortunately, many "providers" can't either.
"Since, as a rule, this shouldn't cost anything, and considering the cost of paying people who know what they're doing, using quality parts, and the necessary amount of work time that few people are willing to invest (regarding PD-related adjustments), but also considering that there are no apparent issues: I would advise you to leave everything as it is, as long as no problems arise."
You can still mess things up enough.
Translated on 08-09-2026, 0:19.
Profile PM WWW Garage |
04-02-2014, 14:51 Subject: Fuel Injectors AVB - Buy Now! |
Okay.
You're welcome! Never touch a running system...
As I said: as long as the consumption doesn't increase significantly, the spray pattern hopefully won't be that bad.
haithamina
Translated on 08-09-2026, 0:20.
