Golf V BLS Simmering: Swing Replacement
chriskross
Post19-03-2014, 9:32    Subject: Golf V BLS Simmering: Swing Replacement Quote
Hello!
Is it possible to replace the crankshaft seal on the transmission side, which is located near the pulse wheel, without using any special tools?
A6 AFB
A6 BRE DPF
Translated on 28-09-2026, 18:08.
Post19-03-2014, 10:15    Subject: Golf V BLS Simmering: Swing Replacement Quote
Since the donor wheel is being replaced, specialized tools are unfortunately likely required.
The second option would be to only replace the sealing ring, but it's likely that the bearing ring will also be damaged. It would require a trial to see.
I would borrow the tool from the icon_lol.gif upon providing appropriate collateral.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 28-09-2026, 18:09.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV ALH: Does G60 flywheel & clutch fit? Diesel Engine Technology
No new posts ESP Replacement: Simmering Guide & Tips Diesel Engine Technology
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
