Leaky Golf 3 Radiator: Other Causes & Fixes
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
bindpe
Karma: +5 / -2   Thank you, like it!
Post09-03-2014, 13:41    Subject: Leaky Golf 3 Radiator: Other Causes & Fixes Quote
Hello.
My car is leaking coolant in the lower left corner of the radiator (see circle).
Unfortunately, I can't really see where it's leaking from. All the connections and hoses seem to be properly connected and dry. It looks like it might be leaking from underneath the radiator.
How likely is it that the cooler itself is defective?
What else do I need to disassemble in order to remove the radiator?
What's the best way to get a replacement? Which engines can I use the radiator from (specifically, an AHU engine with air conditioning but currently not in operation)?
"By the way: Can anyone tell me how to bypass the button on the dryer so that the control unit no longer registers an error? The air conditioning has been out of service for a long time. Unfortunately, this blinking of the climate control system is really annoying."
Thank you for your help.
 File name:  CIMG1071_klein.JPG
 File size:  956.79 KB
 Downloaded:  1038 times
 File name:  CIMG1070_klein.JPG
 File size:  1.94 MB
 Downloaded:  1351 times
 File name:  CIMG1069_klein.JPG
 File size:  1.57 MB
 Downloaded:  4288 times
Golf III TDI AHU 402Tkm
Spritmonitor.de
Translated on 13-08-2026, 3:02.
haithamina
Post09-03-2014, 18:32    Subject: Leaky Golf 3 Radiator: Other Causes & Fixes Quote
It's probably because the radiator is corroded.
Check this out: /viewtopic.php?t=23332&highlight=k%FChler
haithamina
Translated on 13-08-2026, 3:04.
bindpe
Post15-03-2014, 12:56    Subject: Leaky Golf 3 Radiator: Other Causes & Fixes Quote
Update:
Debugging revealed that only a "spring clip" was defective. It had lost its tension and simply broke apart when viewed at an angle.
Spritmonitor.de
Translated on 13-08-2026, 3:05.
Post15-03-2014, 23:16    Subject: Leaky Golf 3 Radiator: Other Causes & Fixes Quote
Thank you for the feedback icon_wink.gif.
No new posts Golf 1J Radiator Leak: Repair Guide & Info Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Pumpe für Scheinwerferwaschanlage undicht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wastegate actuator for turbocharger stuck. Solved Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Workshops are driving me to despair: LLK is leaking Diesel Engine Technology
No new posts Zuviel Ladedruck: Was kann es noch sein? Diesel Engine Technology
No new posts Adjusting 2-Needle Loppers: Where to Find Service? Diesel Engine Technology
No new posts LL Service: What event can trigger it? Diesel Engine Technology
